20 Damn Mhz
Discussion in 'Hardware' started by Clearion, 6 Oct 2005.
  1. Clearion
    Clearion What's a Dremel?
    19 Aug 2005
    Hello, i'm trying too overclock my computer a bit. my goal is too reach 2400Mhz, but it won't run Prime with more than 2380:blah:. I have maximum Vcore voltage, divider on the ram doesn't seem to do any good and i have pretty low temps, what can i do? :confused:
    Edit: System in sign.
  2. TMM
    TMM Modder
    12 Jan 2004
    What do you have the LDT set to?
  3. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    As you are using an XP3200 is it multiplier unlocked or are you trying by FSB alone.
    If it's by FSB then maybe the RAM is maxing out, have you tried increasing the vdimm.
  4. Clearion
    19 Aug 2005
    No, its an A64 "Venice", i haven't tried increasing vdimm, but since it didn't help with divider on the memory, i don't think that's the problem, mabye i scould try it anyway?
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Sorry I didnt even see the A64 part :duh:
    God, I really need to read the thread properly, didn't even see that you had tried a divider to reduce RAM speed.
    So that sort of rules out the RAM or memory controler, leaving the CPU as the main concern.
    What about lowering the HTT multi
  6. Clearion
    19 Aug 2005
    Tried setting the vdimm to 2.80v. running Prime 95 now, yes i thought about the HTT multiplier, bot what should i set it to?
  7. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    You should be able to make 2.4ghz from a venice tbh, most of the winnies did that, even the poor clockers.
    Can you post the settings your running? LDT multi, fsb etc, vcore and such. Check the sink itself, how hot is it getting?
    Also, how long will prime run for before it fails?
  8. Clearion
    19 Aug 2005
    1.550Vcore
    238fsb
    10x multiplier
    HTT multi set to "auto"
    Vdimm 2.80V
    locked pci and pci-e
    Sink feels cold
    prime just gave up on me, had run for about 40-45 minutes (longer than it usually does)
    Can't think of anything else at the moment
  9. Highland3r
    25 Jul 2003
    What happens if you drop the vcore?
    Manually set the LDT/HTT multi to 4* and see how that fares.
  10. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey
    does it actually boot at 2400mhz?
    if so, and you can do your normal stuff, i.e, use your fave programs/games then you should be ok.
    my pc at 3.6ghz isnt quite prime stable but otherwise is as solid as a rock running games and the like so thats all that really matters, its the ram that was giving me the prime errors by the way.
    good luck.
  11. Clearion
    19 Aug 2005
    If i drop the Vcore i only get lower MHZ, il try setting the HTT multi to 4X, But what's LDT? can't find it in the Bios.
  12. Highland3r
    25 Jul 2003
    LDT = HTT multi, its called different things in different bioses.
    Interesting, it might well be that the CPU IS maxing at those speeds. Do you have any idea of its stepping/week or batch code at all?
  13. Clearion
    19 Aug 2005
    Stepping:0
    don't know the other stuff.
  14. Clearion
    19 Aug 2005
    Now running Prime95 With HTT Multi set to 4X
  15. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    Out of curiosity, what is your cooling/temps?
  16. Clearion
    19 Aug 2005
    CNPS7700cu 32C idle, 47C load:)
    Well, the 4x HTT multi thing didn't work either.
  17. Firehed
    15 Feb 2004
    Try increasing the chipset voltage a notch if you can.
    You might have hit the CPU's limit regardless though.
  18. Highland3r
    25 Jul 2003
    Indeed thinking its the cpu's limit. If you drop the mutli a notch, try upping the FSB and see how much more you can push. This might indicate if its a chipset or memory limitation rather than a CPU :)
