3000+ or 3200+
Discussion in 'Hardware' started by Neogumbercules, 14 Apr 2005.
  1. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Would I be better getting the 3200+ and overclocking it to 3500 speeds or should I save the 50 dollars and get the 3000+ and oc that to 3200 speeds? Right now im leaning towards the 3200+ but is it really worth the money? :confused: :confused: :confused: :confused: :rock:
    felt like sticking in some random smilies.
  2. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    with the right setup a 3000+ will easily OC to 3800+ speeds,
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Indeed, 2.4ghz should be do-able, its a slight gamble though, some chips wont even break 2.3ghz..
    Another factor is the multiplier, you'll need 244 fsb to get 2.2 ghz (3500) with the 3000 (9* default multi), and 220 with the 3200 (default 10*).
    If you're ram is poor and wont overclock then both options may require you to run a memory divider.
    220 @ 5:6 divder puts memory at 183, 244 with the same divider puts memory at 203. If you have decent ram however then this wont be a problem,
  4. Yiping
    Yiping What's a Dremel?
    8 Mar 2005
    so far my 3000+ is at 2.298ghz...
    can onli hit 255 x 9... :sigh:
  5. Highland3r
    25 Jul 2003
    Try a little more vcore?
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    :eyebrow: your complaining about that?
    a 500mhz Oc is nothing to sigh about :blah:
  7. Guest-18698
    Guest-18698 Guest
    yer what mother board are you using iv hit 2.5 easy just the temp hits teh roof well nearly lol, so i bemch it on 2.4 ish , i have same chip and the av8 3rd eye :rock:
  8. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Wait for a few weeks until the Venice is widely available and get a 3000+; At the stock voltages those CPUs churn out 800 Mhz overclocks on the stock heatsink or is so rumoured :naughty:
  9. 25188201
    25188201 What's a Dremel?
    5 Apr 2005
    I've just got a 3000+ was gonna start OC'ing it tomorrow will let you know were i get
