Modding 360 Power switch Q
Discussion in 'Modding' started by Noobkiller, 5 Jun 2007.
  1. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    How do you create a button,switch, whatever, similar to the button found in the X-box 360
  2. the fodder
    the fodder What's a Dremel?
    26 Jun 2006
    you put a piece of flexible plastic over a normal microswitch. or are you talking about the lights? (add LEDs)
  3. Noobkiller
    11 Jun 2006
    How do you suggest to attach it?
  4. DougEdey
    5 Jul 2005
    They're standard discrete pieces of acrylic with a diffuser over the top. Each piece of plastic has one green and one red small LED behind it turned on as and when required.
    The acrylic is attached to the PCB.
  5. Noobkiller
    11 Jun 2006
    alright, but how do you suggest attaching the plastic piece to the tact or micr switch?
  6. saltynay
    saltynay What's a Dremel?
    12 May 2007
    celotape :D
  7. mattthegamer463
    26 Nov 2004
  8. Noobkiller
    11 Jun 2006
    Another q, where can I get these "diffusers"?
  9. mattthegamer463
    26 Nov 2004
    Anything that will diffuse the focused beam of an LED. A plexi "light pipe" will work, or if space is limited some sanded plexi can work as well. Also sanding the LED can help, but that won't work for surface mount LEDs.
