Graphics 6800xt better then 7600gt?
Discussion in 'Hardware' started by mr.nice guy, 20 Jan 2007.
  1. mr.nice guy
    mr.nice guy What's a Dremel?
    13 Jan 2007
    HI GUYS, i´m about to upgrade my video card & i can´t decide which one of this to cards is better:
    NVIDIA GeForce 7600 GT 256MB DDR3
    (PV-T73G-UGE3, PV-T73G-UGE7)
    Memory Clock:
    1.5 GHz
    Clock rate:
    580 MHz
    Chipset:
    7600 GT
    Memory:
    256 MB
    Bus Type:
    PCI-E
    Memory Type:
    DDR3
    Memory Bus:
    128 bit
    Highlighted Features:
    TV Out , HDTV ready , Dual DVI Out
    NVIDIA GeForce 6800 XT 256MB DDR3
    (PV-T42E-UDE3)
    Memory Clock:
    1 GHz
    Clock rate:
    350 MHz
    Chipset:
    6800 XT
    Memory:
    256 MB
    Bus Type:
    PCI-E
    Memory Type:
    DDR3
    Memory Bus:
    256-bit
    Dual DVI Out , HDTV ready , TV Out , SLI ready
    as you can see above the 7600 has more memory clock,but the 6800
    has a lot more bus.
    hopr you can help me thanks.
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    The 7600gt actually performs quite a bit better, and has HDR support.
  3. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    7600GT has 4 more pixel pipelines and a much higher core clock. Core and pipelines are much more important then memory.
  4. mr.nice guy
    13 Jan 2007
    thanks a lot! for taking the time and helping me decided.
    by the way what is hdr support.
  5. Gravemind123
    26 Aug 2006
  6. mr.nice guy
    13 Jan 2007
    thanks again!,bye.
  7. BFGunrunner
    BFGunrunner What's a Dremel?
    13 Mar 2006
    The 6800xt supports HDR as well. But get the 7600 gt instead of the 6800.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    in fact nvidia used the 6800XT to use up broken cores and to replace the 6600GT as they stopped making it.
    My 7600GS out performed the 6800XT i owned. long story...
    6800GT died, replaced with 6800XT (naff and run to hot) sent back and refund. purchase 7600GS, runs great!
    BF 2 @ 1280x1024 on high/medium settings :thumb:
  9. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    Agreed with everyone.But it depends upon u that what type of games u play.Like i like racing games,so my preference would be a card with higher bandwidth.There is no difference between the bandwidth of these two.6800 XT should have higher bandwidth but it has same as of 7600 GT.
    Anyways 7600 GT is a better performer!!!
  10. Austin
    Austin Minimodder
    16 Jul 2004
    :D The fastest 6800 cards released were the GT & Ultra and the 7600GT often beat them despite having much lower memory bandwidth. No question, 7600GT.
  11. Krikkit
    21 Jan 2003
    Memory bandwidth can't make up for a slower core. Racing games are just like any other - the fastest overall card will, probably, be the best performer.
