Hi everyone, After my project blue I decide not to waste time and to start new one This time the main colors will be white and silver. I hope to achieve the same success as the previous project did So the hardware involved: - NANOXIA Deep Silence 6 Rev. B - Seasonic 1000 Platinum - CPU - Intel Core I7 5820K - ASUS X99 PRO - EVGA GTX980 ACX2.0 - RAM - Corsair 16gb/2666mhz DDR4 - Kingston HyperX 3K 120GB SSD Water Cooling Parts: - EK-Supremacy EVO - Nickel (Original CSQ) - EK-FC980 GTX - Nickel (Original CSQ) + Backplate - EK-XTOP DDC 3.2 PWM - Plexi (Original CSQ incl. pump) - EK-DDC Heatsink Housing - Nickel - EK-RES X3 250 - XSPC RX360 V3 x 2 - NANOXIA hard tubing - fittings - bitspower Sponsors : This is the place to say a big thanks to NANOXIA.They was so kind to provide me the case,cables,aqua pure water and the hard tubing for my project Last but not least I want to thank EKWB. They provide me all the parts for the water cooling loop.Thank you guys I was planning this from very long time but never have time to do it,work bench This is the project made with google sketchup Not many photos of the work , I was in the rush Job almost complete And work place ready for modding I also made a shelf and installed better lighting My missis was very happy,that I'm not going to use the dinner table any more Ok,enough talking lets start modding Case stripped I can easily fit inside two triple radiators, it makes me very happy First I will replace the standard case feet with those with wheels More cutting,drilling and more weight reduced I'm planning to cover the inside with white acrylic and make a lower chamber. First everything from cardboard And what the inside will look very roughly The HDD cage will be just in front the PSU Wow that was very long writing That's all for now lads.I will come back soon with more photos,so stay tuned for more
It's been a busy week for me at work,so I manage to made some progress today.I start cutting the acrylic. First sheet Drilling holes,so the front panel can fit on properly on place It's time for the second panel And the final result Not bad at all.I still need to fix the supporting bars,cut the the front panel and install the radiator.I'm planning this for tomorrow,so stay tuned for more
I've made some progress today and yesterday. The openings for the front radiator are ready My trusty jewellery motor next to the dremel Back from the past-Made In GDR.Still working perfectly since 1980 And in action And the rads in place with some of the hardware Now it's time for painting.Stay tuned for more
Another update from today with some photos of the painting job. Good scrubbing of the rads Ready for few coats of primer And job done I couldn't resist to apply the silver color on one of the parts Looks promising That's all for now.Very soon there will be more photos
Hi everyone, Another update with photos Until I was waiting the paint to arrive, I decided to make a new front grill for the case. Starting with piece of acrylic Cutting the existing front panel,so the new grill can fit Final adjustments on the front panel And the grill fits perfectly on place Still gonna be like door Existing doors needs to be cut It's time to do the grill And the final product There will be a mesh between the grill and the existing doors and I'm planning to add something in the middle,so stay tuned for more
Wow. In the last article furiously Plus - what we must have patience, I would have died twice during this process.
Hi guys, I'm showing some photos of the progress from last two days. I've made silver coil with my previous project blue,this time I decide to go further and to do something more than simple coil.So here we go I will do EK anticyclone plate from fine silver Usual tools for my projects Not really easy to cut,the silver plate is 4 mm thick But I've done it Final touches with the files And the plate is ready That is all for today.Stay tuned for more
nice, that is one very cool anti-cyclone plate... but I thought ek's offical standpoint was that silver is a no-no and voids their warranty regardless, it looks awesome, and would love one for my res!
don't worry, I know that... just thought it was a bit ironic, that EK dosn't want people to use silver, and then you go and carve an ek logo into a big slab of silver and put it in the middle of the res...
