Electronics 9v brushless dc motor
Discussion in 'Modding' started by Snipes0990, 16 Apr 2007.
  1. Snipes0990
    Snipes0990 What's a Dremel?
    4 Oct 2005
    i am looking to control a 9v brush less dc motor (the Lego mindstorms kind) using pwm signals to control speed generated by a basic stamp micro controller can anyone recommend a schematic. thanks
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    I've never dealt with brushless motors before but after some searching, this might be of some help to you.
  3. Snipes0990
    4 Oct 2005
    Ok never mind the brush less part, lets just say that i want to control two 9vdc motors using pwm signals to control the speed generated by a BASIC stamp micro controller, i am wondering if anyone has done this so that i can avoid buying an actual chip that controls this stuff for sozbots
  4. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Lego doesn't have brushless motors.
    They are brushed.
    FYI, Brushless motors are far more complex to drive than normal brushed motors.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    PC fan motors are brushless; they're easy enough to PWM control. ;)
  6. Macaba
    Macaba What's a Dremel?
    4 Mar 2006
    Thats missing a crucial fact though, Wolfe is right. Its just that PC fan motors have built in controllers, which are able to withstand PWM.
  7. Xiachunyi
    3 Nov 2003
  8. Wolfe
    7 Sep 2003
    Har Har
  9. Snipes0990
    4 Oct 2005
    ok nvm the whole brushless thing, lets just say i wanted to control a 9v motor and drop the speed using a lm317t voltage regulator i could have multiple lm317's set for diff voltages and thus diff speeds but is there a way to adjust one or resistance using a pwm signal generated by a basic stamp micro controller
