Windows Adobe flash plugin crashing
Discussion in 'Software' started by Lithium, 31 Dec 2010.
  1. Lithium
    Lithium super spunk
    26 Jul 2002
    Having problems Adobe shockwave plugin crashing all the time? I have tried re-install flash player. Reinstalling firefox, using IE and google chrome but still happens...grrrrrrrrrrrr
    On the test adobe shockwave player website it appears to be working fine....
    Any ideas folks?
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  3. Lithium
    Lithium super spunk
    26 Jul 2002
  4. Fingers66
    30 Apr 2010
    Uninstall, clear down all temp & cache files (e.g. using CCleaner) then search your hard drive for all instances of "fl*.ocx". Delete any flash files found. Then go to your Windows\system32\Macromed directory and delete it.
    If you have Java installed, it may also be worth going to the Java control panel (in Control Panel, 32 bit section) and clearing any Java cache if CCleaner hasn't done so.
    Reinstall Flash and try again.
    bulldogjeff likes this.
  5. bulldogjeff
    2 Mar 2010
    I had the same problem, it ended up doing my head in. Try deleting Google chrome of fire fox and adobe. Run CCleaner to clean it all up and then reinstall it all again.
    Edit: Ninja'd:duh:
  6. Lithium
    Lithium super spunk
    26 Jul 2002
    Still no joy guys :(
  7. Fingers66
    30 Apr 2010
    What are you looking at when it crashes and in which browser?
  8. Lithium
    Lithium super spunk
    26 Jul 2002
    Anything on You Tube mate or any VOD service.
  9. Lithium
    Lithium super spunk
    26 Jul 2002
    wooot. Just got it working. Totally deleted Java and reinstalled.
    Thanks for the help guys.
    thehippoz likes this.
