Modding Advice on Soldering Irons!
Discussion in 'Modding' started by ISJX_Ian, 23 Dec 2001.
  1. ISJX_Ian
    ISJX_Ian What's a Dremel?
    23 Dec 2001
    Well, its time I do some mods to my case, and get my watercooling all integrated with a fanbus - so I'm gonna get me a soldering iron for christmas :)
    Question is - Butane powered or Electric? Pricewise they are about the same, and butane is very cheap (probably less than electricity :D)
    Anyway - what do you guys recommend? Also what power rating should I be looking at for a general purpose soldering iron that I may one day use to solder a few components onto PCBs (although probably not Surface Mounted components)
    Cheers,
    Ian
  2. RTT
    RTT #parp
    12 Mar 2001
    i use a 50w Draper soldering iron for everyday use :)
    you can get them pretty cheap, just make sure its over about 40w and it should serve you well.
    hope this helps :)
  3. ISJX_Ian
    23 Dec 2001
    well the butane one I was considering is 75W variable temperature, which I liked the sound of :) Sadly the only choices I have are the ones available at Maplin, as its about the only place I know that'll be open tomorrow.
    Here's the gas one, £49.99, 75W variable, and here's the electric one, £44.99, 50W variable temp
    That might help narrow things down a bit :)
  4. RTT
    RTT #parp
    12 Mar 2001
    youve posted the same link twice ;)
    that butane one does look tempting :D
  5. linear
    linear Minimodder
    5 Oct 2001
  6. linear
    linear Minimodder
    5 Oct 2001
    Oh, and I wouldn't recommend a butane iron as your primary tool. They're great for carrying around in a toolkit though. I carried one a few years ago and it saved the day a time or two. Make sure you carry solder too....
  7. ISJX_Ian
    23 Dec 2001
    Any particular reason why? I've been looking for someone who's used a butane one before, get some first hand comments on one :)
  8. macroman
    macroman The One
    3 Sep 2001
    I agree. Butane is not really suitable for the kind of soldering you are likely to do around your PC. You will probably do more damage burning stuff than making things work. ;)
    a 25W electric iron with a small to medium tip , (1/8"), would be plenty for most jobs.
  9. ISJX_Ian
    23 Dec 2001
    so you dont think its worth forking out the extra fortune for temperature control?
  10. K
    K 528491
    31 Oct 2001
    I dunno, these are what we use at work ;)
  11. ISJX_Ian
    23 Dec 2001
    maybe I should cancel my order of my 2 80GB maxtor HDD's and get one of those for christmas instead then :)
  12. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    thats expensive
  13. K
    K 528491
    31 Oct 2001
    They're good for reworking on QFPs and ICs on PCBs though :D
  14. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Ive got both and the butane one is great for in the garden shed or carrying arround in your tool kit and heats up in about 15 seconds. Electric is a bit better indoors but takes much longer to heat up.
  15. ISJX_Ian
    23 Dec 2001
    to tell the truth I am not so bothered if the gas ones arent quite as good as the electric ones, as long as its sufficient for simple soldering jobs for now I'm happy. If it had some major flaw I'd think again, but the convenience of not needed a socket to plug it in, and the lack of cord (and the blow-torch feel :D) make me think it may be worth the few downers
  16. ChriX
    ChriX ^
    30 Aug 2001
    Me too, it serves me well :)
  17. ZeffriN
    ZeffriN What's a Dremel?
    11 Sep 2001
    If your soldering anywhere near transistors or PCBs, you want something like 15 to 25watts...
    Butane does sound cool, but you can't leave em on for an hour at a time... If you're doing a whole project you can leave your electric in it's stand while you place stuff and not worry about it.
  18. brutal
    brutal What's a Dremel?
    7 Nov 2001
  19. Fatboy
    Fatboy Bored
    8 Oct 2001
    I got a 100w electric soldering iron but it is crap because the end is kind of a loop of wire (bout 1cm top to bottom) and it heats up too damn quick- as in 5 seconds :eek: ket a slow small one 'tis much better. Maplin do ones with interchangeable ends so you can use fat or thin ends when soldering.
  20. rK@NE
    rK@NE Rover's gonna get it...
    20 Dec 2001
    My Antex 25w has seen me proud through the years and it's British made so that can't be bad.
    Personally I've never seen the need for anything with a higher wattage but there you go :D
