Graphics AGP Upgrade Advice
Discussion in 'Hardware' started by LogicalChaos, 27 Jun 2006.
  1. LogicalChaos
    LogicalChaos What's a Dremel?
    24 Aug 2004
    Well after a few good years my asus 6800 GT has just died on me :waah: Im going through withdraws not being able to play WoW Lol but anyways my question is should i buy a new card or should i replace the card i had and buy another 6800GT one thing i need to mention is that the video card is ""AGP"" so if i did upgrade i would need a agp card. My money is tight right now but in about a month im going to be able to spend around 300$ on a new card it has to be able to play WoW HL2 CSS ect. So what do you guys think should i go for a small upgrade? i plan on buying a new comp once Vista comes out so i still need a decent card to get me there, im also really intersted in what ATi has to offer at a midrange i havent really looked into there cards but thanks every one any advice would be appreciated.
  2. sandys
    sandys Multimodder
    26 Mar 2006
    What CPU do you have? You can get the 7900GT with 512Mb on AGP from Gainward and its very fast but depending on CPU it maybe better/cheaper to by a new motherboard with PCI-E and a PCI-E GPU
    Edit saw the $ and thought pounds, oops.
  3. LogicalChaos
    24 Aug 2004
    I have Amd64 3400+ its clocked at like 2.4 or 2.2 and i have a gig of cheap kingston ram in there "I need a upgrade with that to :duh: "
  4. atanum141
    22 Jul 2004
    As She/He said, as the Gainward card costs so much it really isnt worth getting AGP anymore and as you have a Athlon64 you might aswell go Pci-e now, and you can take over all your hardware u currently use minus the gfx card.
    im sure $300 is enough for a 7600GT or a X1800GTO.
  5. chemo
    chemo True Jungle Brother
    20 Feb 2005
    take a look here for socket754/pcie motherboards. pretty good prices so a upgrade to one should deffinately be possible with $300 :)
    click here
  6. Max Tractor
    Max Tractor Minimodder
    15 Jan 2006
    I would not drop huge amounts on AGP, either try to pick up something similar to the gt 2nd hand, another gt/unlocking 6800, or go for pci-e
  7. LogicalChaos
    24 Aug 2004
    Great thanks everyone I think im going to go the socket 754/pcie route. So it looks like all also be getting a new mobo along with the video card =P
  8. nigelnathan
    nigelnathan What's a Dremel?
    13 Jul 2006
    upgrade
    I would go for intel core 2 duo motherboard with SLI PCI-E probably the gigabyte offer since that board can supposedly take the future 4 core chips.
  9. iddqd
    iddqd Minimodder
    6 Feb 2006
    Not like that blows his $300 budget out of the water or anything...
    Are you sure you want to go 754? The nforce chipset (if you go with it) really isn't as good as the 939 chipset, at least in my personal experience.
