akasa 460W PSU
Discussion in 'Hardware' started by sexykitten, 14 May 2004.
  1. sexykitten
    sexykitten We love Jaz
    12 Oct 2003
    has anyone got the Akasa 460W PSU. I can get it for £61, same as the Tagan. are both a good buy?
  2. Carbon
    Carbon Banned
    8 Jan 2003
    i never knew that akasa made psu's? do you have a link?
  3. sexykitten
    12 Oct 2003
  4. Tim S
    Tim S OG
    8 Nov 2001
    I saw the PSU's at CTS2004, they're new to the market and I'm not too sure whether anyone has tested them yet as such... review wise. ;)
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    I can stand by the tagan though. That would be a definate good chioce, you could be chancing it with the akasa.
  6. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    Yeh ill second that for the Tagan. Tons of glowing reviews and a proven solid and stable PSU. Totally happy with mine. Just paired it with a new NF7-S mobo, tweaked the voltages a bit and the they're are all spot-on with hardly any fluctuation at all.
    As for Akasa, it seems to be their first proper stab at a PSU, so i'd wait for a shedload of good reviews ('specially one from here ;)) before i parted with the cash.
    The Tagan is well worth the dough. The only little niggle is the amount of cabling that spews forth from it. If you've got plenty of room at the far end of yr case (next to the mobo, and behind the CDROM and HDD racks) you should be able to cable-tie it out of the way without any problems.
    :thumb:
  7. Xen0phobiak
    8 Aug 2002
    I find the cabling just right actually, its the 1st time i havent had to use splitters, just use the velcro ties provided.
  8. sk8o
    sk8o What's a Dremel?
    22 Jan 2002
    That including vat or excluding, cheapest i can find is 71 + p&p the akasa is 57 + p&p
    Ive always liked the idea of 1 single 120mm fan,
  9. Ducarii
    Ducarii What's a Dremel?
    19 Feb 2004
  10. unclean
    unclean SMP obsessive
    30 Dec 2003
    Yar, where is this £61 Tagan?
  11. sk8o
    22 Jan 2002
    Yep i know i have split personaility post syndrone
