CPU AMD 7000-series launched (with a price cut!)
Discussion in 'Hardware' started by IanW, 30 Aug 2022.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    And the most important frame of that video is:-
  2. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Still going to be an expensive upgrade with a new Mobo and DDR5 required - however the IPC improvements do look significant (in particular from 3XXXX series)
  3. RedFlames
    23 Apr 2009
    Don't be too hasty - haven't seen motherboard pricing yet [actual pricing not AMD's nebuluos 'from' prcgin]...
    ...plus DDR5 still isn't exactly cheap
    So Cpu pricing might be about where 5000 series was but total platform costs could be higher...
    [EDIT - Spraduke types faster]
    Spraduke likes this.
  4. sandys
    sandys Multimodder
    26 Mar 2006
    Looks awesome. They have been executing well, just don't need it but will no doubt transition over at some point.
  5. David
    7 Apr 2009
    I'll be skipping this line. Same as the new GPUs from both camps (I'm not counting Intel as a viable GPU manufacturer yet) - I won't need anything for quite some time. Which is just as well - it'll give the new chipsets a chance to stabilise and give DDR5 a chance to come down from the stratosphere.
    SuperHans123 and adidan like this.
  6. adidan
    25 Mar 2009
    I'm going to up my CPU to a 5700x/5800x and pick up a GPU from this gen when I see a price I like.
    Likewise waiting for AM5 to stabilise (helped me with AM4 as I went straight to a Mortar Max rather than picking up a Mortar early on that couldn't handle bios updates).
  7. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    I’ll be waiting for the APUs to launch. I’m really keen to see what they can do with some RDNA cores on board, even if they are alongside Zen3 CPU cores.
    I don’t think my 5900X will need replacing any time soon - it’s more powerful than I really need already.
  8. sandys
    sandys Multimodder
    26 Mar 2006
    They all have RDNA 2 GPUs, though small 2 core ones.
  9. adidan
    25 Mar 2009
    Oooh - i did not know they all had them. Be good to see what they're capable of on their lonesome.
    Will be interesting to see what full fat APUs perform like too.
  10. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    I recall someone saying the onboard is really only for diagnostics, so I wouldn’t expect a lot from the main line of chips. But the proper APUs with a decent number of RDNA cores could be very interesting.
    Arboreal likes this.
  11. adidan
    25 Mar 2009
    Ah right.
    Yeah, the APUs could be pretty tasty.
  12. Omnislip
    Omnislip Minimodder
    31 May 2011
    With electricity prices as they are it’s not a great time to pull up the TDP off at least the X600x part!
    It’s also not brilliant for my little SFF box, either. I’ll be holding off on another generation or two, also thanks to the RAM and mobo costs highlighted already
  13. wyx087
    wyx087 Multimodder
    15 Aug 2007
    It's disappointing to see AMD upping the power limits of their line-up.
    I wonder how the lower powered ones will do with the tiny iGPU said targeting encoding and decoding. Currently running a i7 7700t as my proxmox host with plex. Would be great to get more cores and higher IPC.
    Same as David, no desire to change for this one, or next few years. Might get a new GPU when rtx5000 is released, second hand 4000 or brand new depends on new one's power efficiency.
  14. Spanky
    Spanky Multimodder
    14 Apr 2010
    Will these not run on B/x550/570 with DDR4?
  15. David
    7 Apr 2009
    7000 series is on a new socket and it's LGA now, iirc
  16. adidan
    25 Mar 2009
    Like @David says, LGA now.
  17. Spanky
    Spanky Multimodder
    14 Apr 2010
    Looks like ill stick with the 3600 for a while then . Wonder how the 5800X3D will stand up against the new ones.
  18. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Yup. LGA 1718 (18 more than Intel :p), and only supports DDR5, so no more "Trigger's Broom" upgrades.
    https://en.wikipedia.org/wiki/Socket_AM5
  19. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I know it's a rumor, but it's a persistant one that there will be some Ryzen 7000 (or 5000+) CPUs for Socket AM4 as well. Obviously they will be 'price point' CPUs rather than high end, but with the jumps in performance AMD are claiming they may still be worthwhile for some AM4 users.
    I hope it turns out to be true.
    Arboreal and IanW like this.
  20. David
    7 Apr 2009
    I heard that too, I'm just a little doubtful about the likelihood.
    Zen4 is geared for DDR5 and pcie5, hence the pin(pad) increase, and I don't know enough about the integration of the memory/pcie controllers to say how easy it is to build for AM4 & DDR4.
    It might be rumours of the APUs, which have been based on previous gen silicon, and would package better for AM4.
    Weren't there also rumours that the additional releases on AM4 would be 3D cache variants of Zen3?
