Overclocking AMD or Intel
Discussion in 'Hardware' started by C:\Joshy, 30 Dec 2007.
AMD or Intel
  1. AMD
    4 vote(s)
    11.1%
  2. Intel
    32 vote(s)
    88.9%
  1. C:\Joshy
    C:\Joshy How much cake can you eat in a min?
    30 Aug 2007
    What CPU's are the best overclockers-AMD or Intel?? I'm building a new rig and whant it to overclock well??
    Any suggestions and comments welcome... thanks
  2. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Intel's Core is the way to go. All of them overclock very well, from the early E6600 (3.6GHz on air is doable) to the newer quad cores. Especially the Q6600, which overclocks like the nuts on air, never mind water. From reading masses of reviews and forum consensus, AMD is in trouble in comparison. Phenom is left to eat dust, especially when the new gen of quad cores comes out from Intel. Okay, it's not that bad, but it isn't the Core killer it was hyped up to be.
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Intel Cheesecake
  4. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Intel. A couple of fanboys have voted AMD, but Intel EATS them. 4.1GHz at least on air with a quadcore? Mmm, yummy.
  5. Dev25
    Dev25 What's a Dremel?
    26 Oct 2007
    Intel Cheesecake (Untill Amd comes with something that can better)
  6. Akava
    Akava Lurking...
    28 Jul 2007
    Im an AMD fan boi all the way tbh, but... the facts speak for themselves, with the Q6600 getting to 3.6 without any trouble on Air, Intel is without a doubt the best at OCing at the moment, and it is at the moment, AMD may yet suprise us.
  7. heir flick
    heir flick Minimodder
    2 Feb 2007
    its got to be intel at the moment simple as that
  8. Jipa
    5 Feb 2004
    No competition. Intel. Unfortunately. (for the customers that really have no real choises)
  9. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    Sadly, B3 stepping for the Phenom would have to be some sort of miracle over B2 for them to come back all the way. Not to mention Penryn is also just around the corner for Intel.
  10. C:\Joshy
    30 Aug 2007
    cheers guys i am on a limated budget so and have seen a cheepish Intel Core 2 Duo E6550 2.33GHz. should his overclock well??
    Thanks again
  11. Gravemind123
    26 Aug 2006
    Yeah, it should do fine at overclocking, its a good CPU.
  12. C:\Joshy
    30 Aug 2007
    cheers budy thanks 4 the advice
