AMD XP+ not doing it's job
Discussion in 'Hardware' started by Bust_A_Cap, 15 Jan 2005.
  1. Bust_A_Cap
    Bust_A_Cap What's a Dremel?
    22 Dec 2003
    Aight well i got my new motherboard and processor working finlaly. Now the only problem is that the processor is only running at 1.7ghz when it is supposed to run at around 2.6ghz. The processor is an AMD XP 3000+. The motherboard is a Chaintech SKT600.
    Any and all help would be great...THANK YOU!!!
  2. Tolsk
    Tolsk What's a Dremel?
    14 Jul 2004
    check to make sure the bios has the fight fsb speed, if it doesnt set it to the right speed
  3. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Yeh just manualy set the speed in bios, Maybe even overclock a little wharlst your at it :D
    slater..
  4. TMM
    TMM Modder
    12 Jan 2004
    Assuming that you have the 333fsb model, the 3000+ runs at 2.16ghz~. It seems like your board is running 133mhz fsb (13*133 = 1.7ghz~) instead of the (correct) 166mhz fsb (13*166 = 2.16ghz~). There should be a setting for the FSB in the bios.
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    TMM is correct the XP3000 does not run at 2600MHz it should be 13.0 X 166 2160MHz
    So change the FSB from 133 to 166.
  6. Kensei
    Kensei What's a Dremel?
    26 Sep 2004
    The only AMD Athlon processors that run at 2.6 Ghz are the FX-55 and Ath64-4000.
  7. Bust_A_Cap
    22 Dec 2003
    alright thanks....i'm going to try with the bios. But also I think I have to set on the actual board cause there are jumpers to set the FSB. I think right now it is just on default so i'm going to try that out.
    THANK YOU!!!!!
  8. myth
    myth What's a Dremel?
    27 Dec 2004
    Operating Frequency: 2.1GHz
    ^ Not 2.6.... :hehe:
  9. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    You shouldn't need to fool with the jumpers, just look in your BIOS.
  10. Stompy
    Stompy What's a Dremel?
    16 Aug 2004
    Some motherboards (such as an ASUS one I've worked with before) require you to set the FSB speed via DIP switches on the motherboard.
  11. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Well the mobo's that require fiddling with switches on the actual mobo tend to be older models...
  12. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    My 3200+ XP needed to have it's FSB upped from 100 to 200MHz when I first installed it. No jumpers needed, just a quick BIOS change.
  13. Bust_A_Cap
    22 Dec 2003
    well i went ahead and changed the jumpers cause the case was off anyways....and it's all fixed now!!! WOOHOOO!!!! Thanks everyone!!!
