Case Mod - In Progress Antec 902 - Fusion
Discussion in 'Project Logs' started by Freddy_95, 10 Dec 2010.
  1. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks to bitspower:
  2. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Ooh! Goodies!
  3. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks to alphacool:
  4. jhanlon303
    7 Sep 2006
    It was a V1 with alu interior? I have a V2 all black. Most excellent!
    john
  5. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    It's the V2, but I repainted, it was getting scratched ;)
  6. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Waba waba :D
  7. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    I bring you updates :D
    Yes, the tubbing leaving the gpu block is kinked but is temporary, until I get new feser tube and liquid, conectors and FrozenQ reservoir :D
    What do you think? I'm also getting mdpc-x sleeving :D
  8. djzic
    djzic Bokehlicious!
    8 Nov 2010
    The green PCB on the network card or whatever it is really stands out. Make an acrylic cover for it and paint the bracket! Also, I hope you get mdpc-x shrink too, the writing on your shrink really stands out! Hope this helps ;)
    EDIT: Also, you might want to get some Acetone and polish your caps with the writing on. If acetone don't work there's always the dremel. :D
  9. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks for comenting, I'm gonna change the wireless card and get an usb one ;)
    The sleeving, is going to be completely changed, the psu is going to be fully sleeved, that is just an extension ;)
    I just couldn't understand this: ''Acetone and polish your caps with the writing on. If acetone don't work there's always the dremel'' what caps?
  10. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    looking good so far. asus did some black pcb wireless pci-e x1 cards, you might see if you can track one of those down.
  11. djzic
    djzic Bokehlicious!
    8 Nov 2010
    These: [​IMG]
  12. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks mate ;) I'll see if I can get one of those ;)
    OK mate. I'm going to try ;)
  13. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Hey guys, I have some updates, I bought MDPC sleeving, new liquid and soon I'll make a photoshot with a DSLR, in this time I'll buy new tubbing and new liquid :D
    Greetz
  14. Droih
    Droih Your too close if you can read this
    17 May 2010
    Great case, love the contrast on the orange/black :D
  15. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice work :thumb:. Just a question : Is-it still the same ASUS GPU with the waterblock ? GTX460 ? I was wondering if they used the reference design (to use a full block).
  16. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks mates.
    GuilleAcoustic: It's an Asus HD6850 custom design :) But it's compatible with all of the blocks :)
  17. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    A photo off what arrived today :D
    :eek::eek:
  18. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Here are the last photos ;)
    Hope you like it :p
  19. benjjamin
    benjjamin needs MORE POWER!
    13 Sep 2010
    yes i do :thumb:
  20. Freddy_95
    Freddy_95 Don't!
    9 Dec 2010
    Thanks mate :)
    I'm currently going to change my VPN655 to a MCP355 because of the lack of space :( and I'll have to buy a new reservoir and conectors :/
