CPU Anyone here any have experiance with Intel RMA on cpu?
Discussion in 'Hardware' started by remus, 1 Jan 2020.
  1. remus
    remus Vanity mate.
    17 Dec 2005
    I'm thinking about buying a 7980XE, when inquiring on one such opportunity I asked about warranty as with such an expensive (at least to someone like me) CPU, we want warranty as it's for business use. However the seller doesn't have an original receipt and was given a "warranty replacement receipt" as his first CPU died.
    I have cut out the details but I wanted to know if I could use this incase I needed warranty support during the period it is covered?
  2. GeorgeStorm
    16 Dec 2008
    For an intel cpu you can check using this:
    https://supporttickets.intel.com/warrantyinfo
    Put in some numbers and it'll tell you whether it's in warranty and then you can arrange it via that as well from memory, was a very easy and smooth process the one time I've done it.
    edzieba and remus like this.
  3. remus
    remus Vanity mate.
    17 Dec 2005
    I had a look on their website: https://www.intel.co.uk/content/www/uk/en/support/articles/000006160/services.html
    What information do I need to provide?
    The following information is required to process warranty requests:
  4. GeorgeStorm
    16 Dec 2008
    Did you put in your cpu's information into the site I linked? Should say whether it's in warranty. Then you should be able to request an RMA from memory.
    You have to give some information such as address, email etc. But I only needed information that was literally on the cpu itself to get things started.
  5. remus
    remus Vanity mate.
    17 Dec 2005
    Yep i've submitted a ticket to see if it's all still in warrenty
  6. GeorgeStorm
    16 Dec 2008
    Unless the system has changed you don't need to submit a ticket, just put in the numbers it asks for and it tells you then and there?
  7. remus
    remus Vanity mate.
    17 Dec 2005
    If it's a replacement CPU does it get a new 3 year warranty?
  8. GeorgeStorm
    16 Dec 2008
    The site should tell you once you've entered the numbers it requires.
    It has links to finding out where to find those numbers on the same page.
