Modding Argh Laquer fingerprints!
Discussion in 'Modding' started by Vaz, 26 Mar 2007.
  1. Vaz
    Vaz What's a Dremel?
    23 Jan 2007
    Hi guys,
    I just got my panels back and whilst handling the 'still wet' panels I ended up touching the panels. Now you can clearly see my finger prints on them. There small but still visible.
    How shall I remove them? The dudes done a few layers of laquer. Shall I simply spray over the [area] again or over the whole thing or is there no chance of recovery now at all?
    Kind regards,
    Vaz
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    depends how deep they are, and how thick the paint is. But you probably have to sand down the whole thing and repaint. (you don't have to sand down to the metal, just the damaged layer.)
  3. Vaz
    23 Jan 2007
    I dont think there too deep. I mean, it's had a hell lot of layers placed onto the origional paint. I think this was the last layer that was drying.
  4. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    if the prints aren't very deep I would let the laquer dry completely and then try some cutting compound (as used on car paintwork etc) to polish them out, just don't go mad with it.
  5. jhanlon303
    7 Sep 2006
    I second the wait till dry and compound idea. But remember laquer dries REALLY slowly, it might seem dry but wait anyway.
  6. Vaz
    23 Jan 2007
    could you please explain a little more on what you mean but 'cutting compound'.
  7. Prometheus
    26 Jun 2004
    Cutting compound is like really really fine sand paper but in a liquid form that you polish out the marks.
    Farecla G3 liquid was what I was thinking about as it's not too abbrassive that it will leave marks (Something like T cut will probably be too abbrasive and leave swirl marks every where).
  8. Slim Slotloader
    Slim Slotloader What's a Dremel?
    19 Feb 2007
    Rubbing compound might do the trick
  9. Vaz
    23 Jan 2007
    So in lamemans terms... liquid solution to dissolve/remove the paint but not damage the metal itself. Got you :)
  10. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    No, no, that sounds more like a chemical stripper. Try something like 3M rubbing compound or Mother's rubbing compound which will just very lightly take off scratches and such when you rub it. If that doesn't work, use a very high grit sand paper to start, like 1000, or 2000 and then use the rubbing compound. Good luck.
