ok, I thought about using one of these in a mod anyone have ideas? thought of cutting it so that it would fit over the faceplate of a cse and making the drives come out if it?
hehe I think a windowed keg as a case would own. stick a res behind the window with some dark yellow dye. would be a nice w/c rig
How big is it? (Can you tell Im not a beer drinker?) Is it a full size keg? If so, I would set the DVD/CDRW so that it ejects through the top. I would try to keep keg as intact as possible to keep the illusion solid. Should be plenty of room inside for all of the components.
if i'm reading the keg right, it's a 5L keg, not the biggest thing, but you could fit something small in it. using it as a res would prolly be the best idea. that's one of the short little things, right. so you'd have to get a small case to replace the faceplate with it. tho you could use a full tower, and put it in the top portion
the keg is 6" large by 9" 1/2 high that would be sweet. and even making it so that the drive goes in and out and that fluid comes out of the keg... I think I'm going somewhere here
"IMAGINE FINDING A COMPUTER! That calls for a Bubba of Computer, Computer, Computer, Com-com-com computer, computer, computer" mini-ITX? Get two and mod your speakers into them, peel some cans apart and sheath your monitor in them and paint your case with your favourite brand...
u won the war because..... we let you. We could have so crushed you if you a) went to sea b) if britain sent more troops over c) wore pretty dresses to draw your attention while we shot you. *runs away from the big bad yankee hoohaaa*
well in fact we use metric measurements in canada but I'm used to use the old imperial system to make a long story short, the imperial system was in place when my parents were born and the metric system got in place when I was was born... so we use both in fact I have Altec Lansing ATP3 speakers and the sound comes from the front and the bottom of the speakers so I don't think it would work... plus I would have to to the same thing with my sub which would take 3 kegs but if I put it on the faceplate of a small case... and make the drive hidden (obviously) and with a plexi drive case, maybe I could try to put liquid in it... yeah I think I figured something good here
