Modding bending plexi
Discussion in 'Modding' started by SoylentGreen, 2 Oct 2004.
  1. SoylentGreen
    SoylentGreen What's a Dremel?
    27 Jun 2004
    yes i know there are things i could search for. i want to know what's the best way. also, how would you attach two pieces of plexi seamlessly? or if this is not possible, as smoothly as possible
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
  3. evilstriker
    evilstriker What's a Dremel?
    29 May 2004
    i used a heatgun that i bought for 20$ at wallmart. It did a very nice job. Only requirements that you need is patience if you dont want to mess up becuase you dont want to burn it you want to bend it hehe
  4. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    as far as attaching it seemlessly are we talking corner? butt to butt. you can use what like acrylic cement where its an acohol and it melts the 2 pieces together. You could probably flame polish the joint, but there's no way I know of turning to pieces into one
