Modding Best tools...
Discussion in 'Modding' started by Alesh, 3 Sep 2005.
  1. Alesh
    Alesh What's a Dremel?
    3 Sep 2005
    ...to cut metal.
    I use dremel but for a perfect cut what tools must to buy?
    Sorry if english isn't correct.
    Bye
    Alesh
  2. zackbass
    zackbass What's a Dremel?
    8 Aug 2002
    It all depends on the composition and thickness of the metal and the type of cut you want to make.
    A Dremel is great for small intricate stuff like artisitc aluminum sheet metal work.
    A nibbler is good for faster cutting in thin aluminum and thinner steel but is imprecise.
    Aircraft snips are great for long straight or curved cuts in thin aluminum and thiner steel.
    A Beverly (Throatless) shear is awesome for cutting just about anything that you can work into its jaws. It makes very nice straight and curved cuts in thick sheet aluminum and somewhat less thick sheet steel.
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=38413
