Black Icemat
Discussion in 'Article Discussion' started by Jamie, 8 Jul 2003.
  1. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Questions, comments ...??
  2. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    does the icemat have any kind of texture to it and is it frosted on the back side? Also any clue as to the type of glass used? Thanks nice review to :)
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    I like the look of this one better than the white.
  4. Reflex
    Reflex What's a Dremel?
    8 Dec 2002
    I have one of the original icemats, its frosted on the frontside but is still smooth. I think its some sort of tempered glass like they use for shelving. Its pretty tough stuff anyway, ive dropped mine a few times, still perfect condition. One thing tho, doesnt seem to work with logitech mice, well the old ones anyway, not too sure about the MX series. :D
  5. Jamie
    12 Mar 2001
    Yes, the surface has a very fine frosting which gives it a slight texture. This is nowhere near as rough as the other surfaces out on the market.
  6. Dave@PCX
    Dave@PCX What's a Dremel?
    9 Jul 2003
    Got one here and it's lovely - been using it for the past few weeks and I'm very happy with it. Ultra-smooth, even with a mechanical mouse.
  7. era
    era What's a Dremel?
    12 Jul 2003
    I have one of these,
    When i want to use it with my Logitech wireless optical mouse it isnt working.
    When i dont use my mouse for 15 sec. en i try to move it ,the arrow on my screen freeses.
    When i puch one button on my mouse then it will move again.
    I have a spare mouse (the same as the otherone) and does thesame :sigh:
    It is making me crasy.
    Who had thesame problem?
    (sorry of my bad englisch, but it is better than your dutch:D )
  8. Jamie
    12 Mar 2001
    I tried 2 different Microsoft optical mice and both work fine.
  9. RTT
    RTT #parp
    12 Mar 2001
    nice review :thumb: might get one myself, pads on my ratpad are knackered :p
  10. era
    12 Jul 2003
    strange, is there someone with a logitech mouse who has a icemat?
  11. Reflex
    8 Dec 2002
    as i posted i tried my dual optical on it but it jumps, seems to me only ms intellis work on this thing, but they work superbly well. Still dont know about the new logi MX series
  12. Jamie
    12 Mar 2001
    I just tried my really old version 1 microsoft intellimouse that used to jump about on the CoolerMaster mouse mat (brushed aluminium) and it works fine. If I can get my hands on a logitech mouse I will try it out.
  13. Pachena
    Pachena What's a Dremel?
    13 Jun 2002
    I have a Logitech MX-700 which replaced a Logitech cordless optical.
    Used them both on:
    • - a "normal" mouse pad (that I prefer only because of it's gel wrist support),
      - a 3M optical mouse pad,
      - and a "white piece of paper".
    Both had similar experiences.
    White piece of paper is best... although I hate using it this way. Am still trying to find a better solution for the MX-700.
    On anything but the paper, the mouse gets erratic. The pointer moves opposite where I move the mouse. Up-Down axis seems to be worse. This will happen after a while of using it... seems to work "normally" at first. I immediately go back to the white paper and it's fine again. Go back to either of the other "real" pads and it will work fine until it doesn't again (few minutes usually, sometimes less).
    Called Logitech Tech-support (last week) and they confirmed that my experiences were normal. Logitech optical mice work best on "light, nonreflective surfaces." They also told me that batteries lasted a lot longer on lighter surfaces as well.
    Am frustrated and keep reading posts hoping to find a decent mouse pad that works as good as white paper with the MX-700 (and other logitech opticals, I guess).
  14. Guest-16
    Guest-16 Guest
    how do u knacker a ratpad?
  15. Jamie
    12 Mar 2001
    A few months playing CS everyday soon wears out the ratpadz surface.
  16. Jamie
    12 Mar 2001
  17. macroman
    macroman The One
    3 Sep 2001
    This may be of some interest to you?
    http://www.bit-tech.net/review/200/
  18. Jamie
    12 Mar 2001
    Bit of a thread revival here but I just got an email from www.euro-tech.co.uk to say that the Black Icemat 2nd Edition is available. The second edition is exactly the same, just 44% larger.
    I think it still has problems with the early logitech optical mice as the compatability list only lists the MX series mice.
    The price is £29.95
  19. Haddy
    Haddy World Domination
    22 Jan 2002
    Wonder if itll ware down as fast as my eveglide giganta
  20. toss
    toss What's a Dremel?
    6 Jun 2004
    I might get one of these my ratz pad gs is wearing smooth in place :wallbash:
Tags: Add Tags
