Modding Bluetooth remote control for pc
Discussion in 'Modding' started by ReFredzRate, 21 Dec 2005.
  1. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Is this possible? I mean, I have a phone with Bluetooth support, and a Bluetooth dongle in the back of my pc. Can I be able to change the volume of Winamp for instance by using my phone?
  2. LockmanX
    LockmanX What's a Dremel?
    8 Jun 2003
    Some phones, like my Sony ericsson z520a have device control that can do stuff like that. Check your manual.
  3. ReFredzRate
    2 Sep 2002
    There's no specific option in the phone. But I am able to install new applications on it, so getting the option on the phone would not be a problem. Only thing is, is there an application that provides me these functions?
  4. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I dunno, my k750 lets me control media player and powerpoint, pretty handy
  5. ReFredzRate
    2 Sep 2002
  6. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    go to www.sparkfun.com and search for "BlueTooth v1.2 DIP Module" with that and a blueooth dongle you can establish a serial connection to a device with that radio, what you do then is up to you.
  7. J()£
    J()£ Banned
    21 Dec 2005
    How exactly does this bluetooth remote work???
  8. ReFredzRate
    2 Sep 2002
    When you're talking about the one I posted, here's the answer: As far as I understand you have to install the downloaded application on your phone. When it's installed you can use the application to do certain things on your computer. But your phone has to support bluetooth, and the pc you use as well.
  9. veland
    veland What's a Dremel?
    2 Feb 2003
    Try this one:
    http://fma.sourceforge.net/
    I'm using it at work, for controlling powerpoint and stuff like that. But a lot of options and fairly easy to use as well!
  10. ReFredzRate
    2 Sep 2002
    Yah... looks alright.
    Problem is, I have a Nokia.
  11. veland
    2 Feb 2003
    I'm using it with a Siemens, so it's not Sony/Ericson only...
  12. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Check out Puppetmaster.. been using it for ½ a year now... works for me on a Nokia 6230 and 6230i
