Modding Building your own keyboard
Discussion in 'Modding' started by Pyrthas, 24 Aug 2006.
  1. Pyrthas
    Pyrthas What's a Dremel?
    17 Jan 2005
    My guess is that I won't have the ability to do this, but I'm really tired of keyboards not having the exact arrangement of keys that I want (the physical keys themselves; I don't care about what functions they're assigned, since I remap a bunch of stuff through the registry anyway). So, does anyone either know of anyone who's successfully constructed a keyboard or know of a company that will do custom keyboards on a relatively small scale (as opposed to all the ones that do them for companies, which I obviously can't afford and in any event don't need)?
    Again, I figure the answer's going to be "keep dreaming," but oh, well. The closest thing I've found is the DX1, but that only supports 50 keys, and I'd like a fully-functional keyboard. (For me, with an ideal setup, that means at least 75 keys.)
    Thanks.
  2. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    2 USB keyboards? should have enough keys...
  3. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    why dont you just buy an xkeys thing and have those keys mapped to what you want and put it next to your regular kb
  4. crazydeep74
    crazydeep74 What's a Dremel?
    25 Jul 2005
  5. Pyrthas
    17 Jan 2005
    Sorry for not being clearer. I want more keys in a small footprint than are currently available. The biggest complaint that I have about normal keyboards, aside from the gigantic footprint, is that the space bar is way too big. I barely use any of it, and I'd love to have a key or two (well, really just an alt key) that my left thumb could hit without distorting my hand (I always use my right thumb for space when typing normally). While buying additional keyboards will certainly give me more keys, it won't let me chop up the bottom row of my keyboard and rearrange everything.
    For now I'm just using a Japanese keyboard (I don't understand any Japanese), because they tend to have a lot of keys close together, which can be remapped, of course (you can see a good image here; that site was really helpful, as an aside, since it had the scancodes for all those keys). It's still not quite what I'd like, though. For one thing, I have to use a mouse bridge (basically, a thing that sits over the right side of your keyboard and functions as a mouse pad) to compensate for the standard-sized footprint.
    Here, I'll throw a quick mockup of what I'd want together in paint. Ignore the black keys; they were just there because I wasnt sure how much room I'd need. I'm sure that I could tweak things a bit more, but this should make it clearer why just buying more stuff to put on my desk isn't going to cut it.
    Edit: I suppose I wouldn't mind a few more keys below those, which would also be accessible to my thumb, but that's not quite as important. This was just tossed together to see how many keys I'd need at a minimum.
  6. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Just get a happy hacking keyboard
  7. Pyrthas
    17 Jan 2005
    Have one. And a Deck. Prefer the Deck, since I like having f1-f12 without a fn key. But neither of them lets me actually *split the space bar up into several smaller keys*, which is why I was asking about building a keyboard.
  8. DougEdey
    5 Jul 2005
    There is an easy way to change the layout of a board. Each key works by shorting two connectors under the rubber beneath each key.
    You can just re-position these, using a lot of soldering.
    Also, look at what this guy did
  9. gbeeby
    gbeeby What's a Dremel?
    6 Dec 2005
    by any chance do you have an ocd in keyboards ??
  10. Pyrthas
    17 Jan 2005
    I find it rather sad that on a forum dedicated to tweaking the hell out of everything else in a computer, attempts to mod keyboards in any significant way are met with such derision. Most of the compuer-using population sees computers as simple tools, not something to be altered significantly. Apparently, most of the modding population sees keyboards the same way. I guess that's kind of ironic, isn't it?
    Thanks for the link, Doug. I figured I might just try resoldering things on my Deck (or, more likely, on a second Deck that I buy just for this), but was hoping to find a record of someone else doing something like that first so that I wasn't just going into things blind.
  11. Denied
    Denied What's a Dremel?
    28 Oct 2005
    Dood. Lighten up. I doubt he was seriously having a go.
    And I would say that a keyboard is a functional part of the computer... in the same way that people don't look to change the underlying operation of a CD-ROM... sure they put windows in them and mount them vertically... but in the end it's still a device we use to read CDs (or DVDs)... A keyboard is much the same. People do mod them... paint them, light them etc... but yes... you are correct, they don't tend to mess with the actual FUNCTION of them.
    I can see what you mean about all the wasted space of the keyboard... I found a keyboard that was a very small footprint and had a half size space bar.
    http://www.elx.com.au/item/elsKB-MINIUP
    Good luck with the search...
  12. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    gbbeby doesn't spit out stuff to make you happy he just implys you might have a mental error or he does.
    But it wouldn't be terribly hard. I may cut a keyboard up for you and slap some pics and such. The main thing is to be able to cut the key's and circuit board then resolder the traces in an appropraite spot. Hard and time consuming but totally possible.
  13. Pyrthas
    17 Jan 2005
    Yeah, I just took apart a couple keyboards after taking a look at the link that Doug posted. Now I just need to decide if I really care enough to buy everything that I'd need. Thanks also for the link, Denied. It's not quite what I'm looking for, but I always like to see more options, in case I realize that I can put them to use later.
  14. MrMacomouto
    MrMacomouto What's a Dremel?
    28 Mar 2004
    You could buy a rough sized touch screen LCD and write your self a small program so you could design the keyboard however you wanted it.
  15. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    wasn't there a keyboard where the buttons could be positioned anywhere on its base and u could have as many or as few keys as you wanted (they were all seperate keys)
    Think I saw this a while back online somewhere
  16. Cabe
    Cabe What's a Dremel?
    14 May 2002
  17. Soncetina
    Soncetina What's a Dremel?
    14 Oct 2005
    a very cool way of doing it would be by using a touch screen as a second monitor, put it face up infront of u (like a keyboard) and then have an "onscreen keyboard" on it. Standard windows comes with an onscreen kb but i doubt ud b able to play with where the keys are etc, but im sure you could find som1 to make one in c++ unless theres one out there already...
  18. the fodder
    the fodder What's a Dremel?
    26 Jun 2006
    I didn't verify key for key but it looks like you have your Japanese keyboard reconfigured to your liking it just the ten key you don't like. Why don't you just cut off the offending appendage? I am planning on doing it to my M$ natural as soon as I decide if I can live with out the arrow keys I want a really small keyboard.. You keyboard probably has like internal connections, just tape and fold over the membrane. this guy has a step by step his end result is just sloppy.
