Modding Bulgin Vandal Switches and Case Mod Idea
Discussion in 'Modding' started by WizardLock, 15 Nov 2003.
  1. WizardLock
    WizardLock What's a Dremel?
    15 Nov 2003
    I am thinking about using a Bulgin Vandal Switch on my case. The theme I am going for is a Radioactive theme.
    Here are 2 pics. I am trying to decide among these to use:
    Here is a description of my case mod I am working on.
    As I mentioned, this is going to be a Radioactive theme.
    On the side panel, I am going to have the Radioactive symbol cut out, with an 80 mm fan in the middle and a clear window behind it.
    For the front, I am having my cd-burner and dvd-rom at the top, and in the third and fouth bays, I am placing a plastic container that will have uranium uv-reactive marbles in it. I will dress up this canister with the proper symbols and everything.
    I will be having EL wire go from the canister and "connect" to the 2 ROM drives above, makling it seem to power them.
    On the bottom right, I bought a plasma globe to go there, to give it a "nuclear" feel with it. Then I was going to add one of those switches shown above to the top of that globe.
    On the other panel, I am placing this sticker on there, in the appropriate colors:
    I am then cutting 80mm blowholes on the top. These will be covered with frozenCPU's Radioactive Grill and also one for the exhaust fan in the back
    Inside, I want to cover all the metal with a flexable diamond-plate metal piece. I will have UV lights inside to illuminate everything, and one 4" light above the marbles.
    Everything will have sleeves on it. I will use UV yellow reactive sleeving on the power supply, and UV green round cables.
    The case will be painted a hunter green, and have yellow lettering all over.
    I hope this sounds "worthy" of a good case mod. Please let me know your comments or sufggestions.
    I will try and add drawings of this later so everyone can see what I am trying to describe
  2. Sounds cool. Personally I would go with the bottom button. I think it just looks better.
  3. Alwayz Dead
    Alwayz Dead What's a Dremel?
    5 Mar 2002
    Hey, like to see it when its done.........sounds good.
    Go for the lower of the two pix of Bulgin buttons I gree it looks better.
  4. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    if your going for a "leaking Radioactive" look,go for the top one.
    the bottom one does look cleaner[​IMG]
  5. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    hey.... where the heck did you find GREEN vandal switches??? I've been looking for some for a while now... :eyebrow:
    especially one like that top one.
  6. Phlek
    Phlek What's a Dremel?
    25 Aug 2003
    hmm, I like the top one more just because I think it would fit the theme of a radioactive case more then the top one. but its just my opinion.
  7. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    The top one fits your mod more i think.
    I also think the bottom looks so much better, but not for what you want!
  8. WizardLock
    15 Nov 2003
    Thank you everyone. So you know where to get those switches, you can go to http://wwww.performance-pcs.com and they have red, green, and blue.
    I think I am going to go with the top button. I appreciate all of your comments, and I will keep a "digital log" of everything I am going to do. :D
  9. Phlek
    25 Aug 2003
    Nice choice, I'd like to see how this turns out....good luck.
  10. KRASH
    KRASH What's a Dremel?
    27 Oct 2003
  11. WizardLock
    15 Nov 2003
    WOW! That pwns!
    But would having the huge Radioactive symbol on the side panel, and then a switch with the same symbol be too much?
  12. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
  13. WizardLock
    15 Nov 2003
    Well then... I will have to try this out. I will let you know how this works out.
  14. WizardLock
    15 Nov 2003
    Just thought of another thing... what about a reset switch?
    What should I do? I would love ideas on this
  15. Phlek
    25 Aug 2003
    Well if you made them you could always just make a smaller one, but if you bought the switch....I'm not to sure. You could always buy both and make one power and other reset switch? or you don't even need to have a reset switch.
  16. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    I like the plain green light…maybe blinking. It has a menacing warning look to it.
  17. KRASH
    27 Oct 2003
    You could have it function as the HDD LED as well green with flashing red fro the hdd activity> That would rule! :rock: :thumb:
  18. whiteagle
    whiteagle What's a Dremel?
    28 Aug 2003
    As far as I know vandal switches are momentary. Don't forget that or you will look like an idiot having to hold down the button to keep the plasma globe on.
    btw, I like the radioactive marbles powering the drives idea.
  19. WizardLock
    15 Nov 2003
    Thank you whiteagle for the compliment.
    Yeah, I am stuck on the reset switch. But if I don't have one, I would have to hold down the power button for 4 seconds each time I need to restart, which in turn sucks.
    As for the plasma globe, it has its own power switch as well... which is another thing I need to work on. It is a switch.
    Hmmmm... :confused:
  20. mence
    mence What's a Dremel?
    27 Nov 2002
    go for the top one, it looks like more what you would find in the military (which would have the radiation)
