Cooling case/cpu temp differential
Discussion in 'Hardware' started by [CpK]Bastid, 8 Oct 2002.
  1. [CpK]Bastid
    [CpK]Bastid What's a Dremel?
    24 Aug 2002
    right now i have a 12c differnece in temp
    33c case 45c cpu
    Im thinking my setup is not as efficient as it could be, or is it?
    opinions?
    setup right now:
    res/pump-->cpu-->rad1-->gpu-->rad2-->res/pump
    2black ice micros positioned behind 2 80mm intake fans
    innovatek blocks
    iceball2 res/pump
    someone suggested i run the rads in parallel so new setup would be:
    res/pump-->2 rads-->cpu-->gpu-->res/pump
    any thoughts?
    thanks
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    what size pump?.......also if its an athlon it may be over heating the water for that size radiator....or maybe ur fans arent enough for the radiator
  3. Haddy
    22 Jan 2002
  4. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    and what cpu/mobo? is that a diode temp?
  5. [CpK]Bastid
    24 Aug 2002
    im just usin mbm5
    the fans are 30cfm 80mm
  6. Haddy
    22 Jan 2002
    ah ur temps are probably alot better then....watercooling = less airflow aroudn the cpu and most motherboards only take readings from the air around the cpu, not the actualyl cpu
  7. [CpK]Bastid
    24 Aug 2002
    i would think its worse then......wouldnt it take alot to heat up the block then the air.....i would think if im gettin the "air around the cpu" temp, the actual cpu temp would be higher....no?
    oh well thanks for the help guys
    any more opinions gladly appreciated:)
  8. TiTch
    TiTch h2o cooled
    19 Oct 2001
    mobo temps are at best a rough guideline, little more. I would however look at the use of two rads. I would definately not use them in parallel unless you are running a linked reserviour system. Radiators decrease the waters velocity and kill the flow rate. I would try running one rad just befor the CPU, see your temps and then play about with configurations a bit.:baby:
