I am building a new PC with a budget of around £600 max and looking at Cheap- ish cases for my system and need some advice about case Fans and airflow I will be running a i5-2500k cpu, and using EVGA NVIDIA GeForce GTX 460 SSC Graphics Card - 1GB. The Zalman Z9 plus Has 4 case fans included and room for additional fans aswell. but it is at the limit of what i want to spend on the case. Or do i buy a cheaper case Like the Thermaltake V3 Black Edition Case that only includes 1 fan and buy extra fans? Or do i need 4 Fans? any help would be greatly appreciated
For a cheap case the antec 100 is the best and it really is worth spending more on a fractal design r3 (I have one and it's great ) Edit: I built my dads pc in an antec and it good other than it has limited room behind the mobo for cable management and the stock fans are loud (although have 3 speed settings). If you can't afford the r3 then the antec would be my second choice.
I have the same case as you have now. I have recently been looking at the Corsair Carbide Series 400R .. it looks like a really nice case and only £80 from scan
Hmmm im not sure i can spend that Amount of money on the case...... i do like the antec 100 and it is definatly an option. Cheers
Got a similar config with an antec 100 recently. Its a budget case that just WORKS. U get a rear 120 mil and a 140mil fan for the top with it. I am planning to buy a couple of 120 fans,for the side and the front. Will cost me 10 quid. So ya, antec 100 + few fans would work just fine.
I do like the Antec 100 but the Z9 plus is around about the same price but has 2 more case fans?? isnt it worth just getting that instead??
Getting a 2nd hand case can save alot of $$$ and you'll never know unless your Pc is over desk or in middle of room
There may be an r3 on the for sale bit soon from what I can see £50 posted if I remember correctly. Sent from my HTC Desire using Tapatalk
that would be nice but im still a newbie so i dont have access to the sale room thing .. i am looking on Ebay for 2nd hand cases but there isnt one that takes my fancy atm but something might come up :O
