Decided to mad another case, to house a somwhat portable system. pics of its in its virgin state and my work so far. still has a fair way to go. opinions welcome.
Oooh, a globalwin 802.3 case! Only sold mine recently. can you post any plans of where you're going wityh this?
pasta? you mean the chunky bit on the bottom? i'm about to cut them off now i have a picture of what i'm doing in my head, not a good anough drawer to put it down on paper though. you'll just haveto wait and see
all i acn see is your aimign for a lot of bog and one blow hole =D, plans would be gret so we can start putting wierd thoughts into our heads as too what this may be turnign into =D
yes there is going to be lots of bog going for a ncie smooth look gonna be squeezing in a radiator for my watercooling, a nice paintjob, still undecided on the colour, gonna be using a bunch of led's for lighting. and whatever you guy may suggest
update, i've been quite busy lately but i've managed to get a bit more work done, they'res so much sanding, o so much sanding a little teaser piccy
Looks really smooth indeed. There's only one thing that spooks around my mind right now. You said you were going for a somewhat portable case. Doesn't the bondo restrict the portability quite a lot? I'm doing some bondo modding on my case as well, and it seems to weigh a ton more than before now.
pepsi max is a sugarless form of pepsi, it jsut uses a different artificial sweetener to diet pepsi or pepsi light. weight isnt a issue with this case this case, compared to my case thats the size of 2 full tower cases side by side, this case is quite petit
But why should you care about Pepsi? Pepsi is already loaded with sweetness and tastes naturally flat and has no bite...
