Modding clear resin
Discussion in 'Modding' started by merlin 65, 27 Jun 2006.
Thread Status:
Not open for further replies.
  1. merlin 65
    merlin 65 What's a Dremel?
    13 May 2006
    i'm going to be starting something that involves using a lot of clear resin ,the stuff that sets solid and is totally clear . does anyone know of a uk supplier that sells it in big quantities and is cheap or an alternative if one exists
  2. merlin 65
    13 May 2006
    nobody got any ideas then
  3. Hiren
    Hiren mind control Moderator
    15 May 2002
  4. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    Dont know about UK sippliers but Bondo makes polyester resin in small quantities or by the gallons, i bought a quart not too long ago for a project, it dries clear enough but not crystal clear, could've been my fault though, the mould i used weren't suggested and i used a lot more hardner than it was described My result had a white hase in it probably due to fast drying :eyebrow:
  5. merlin 65
    13 May 2006
    just to give you a rough idea of how much i need , i require enough to pour 1 inch deep and make 3 panels 36 inches square
  6. Kobalt
    26 Aug 2003
  7. merlin 65
    13 May 2006
    because im casting something inside the resin and it needs to be a solid surface but its more about the casting side
  8. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
  9. Kobalt
    26 Aug 2003
    Then the bondo polyester stuff is definitely worth looking into it sells in small quantity, just get a pint and do tests :thumb:
  10. Whelan_999
    Whelan_999 What's a Dremel?
    4 Jul 2005
    If I done this right you need 98.7 L of clear resin, make it a even 100 incase.
    36x36x1=1296
    1296x3=3888
    3888inches x 2.54=9875.52
    9875.52x10=98755.2cm squared
    98755.2/1000=98.7 L ... I think..
    -aaron
  11. Nezuji
    Nezuji What's a Dremel?
    23 Oct 2004
    Whelan_999, close but no cigar; You need to be more careful about converting between squared or cubic units. And I can't even guess where the 10 in your second-last line came from.
    If we're talking about three square panels, each one inch deep and 36 inches on a side, that'd be:
    36 * 36 * 1 = 1296 cubic inches.
    1296 * 3 = 3888 cubic inches for all three panels.
    1 cubic inch = 2.54 * 2.54 * 2.54 = 16.387064 cubic cm.
    3888 * 16.387064 = 63712.904832 cubic cm
    63712.904832 / 1000 = 63.712904832 litres
    However, if we're talking about three panels, each one inch deep and 36 square inches (i.e. 6" by 6") in profile, that comes to:
    36 * 1 = 36 cubic inches.
    36 * 3 = 108 cubic inches for all three panels.
    108 * 16.387064 = 1769.802912 cubic cm.
    1769.802912 / 1000 = 1.769802912 litres
    Of course, all of this assumes that:
    a) merlin 65 plans on buying the resin in metric quantities, even though he or she has provided imperial measurements, and
    b) resin occupies exactly the same volume when set as it does when fluid.
    Nezuji :)
  12. padair
    padair Inebriated
    20 May 2004
    As he's in the UK he will have to use metric quantities - unless he imports it from the states.
    It's easier to do if you convert the imperial to metric measurements at the start - you can use the value of 2.5cm for an inch instead of 25.4mm so the 36" becomes 90cm - a lot easier to find on a ruler / tape measure and for the resulting volume, a measuring jug.
    90*90*2.5 =20250cm3 / 1000 = 20.25 litres/sheet
  13. sykocus
    sykocus What's a Dremel?
    12 Mar 2006
  14. merlin 65
    13 May 2006
    ok i didnt explain it right i want 3 pieces each one 36 inch by 36 inches , and i dont use metric cos im old school
  15. merlin 65
    13 May 2006
    all i want really is a place where i can buy it by the gallon and not in poxy little tubes lol and in the uk
  16. Whelan_999
    4 Jul 2005
    The 10 in my second last line was to put cm into mm then divide by 1000 to get L. I dunno if dividing 63712 by 1000 is right. But when I think about it my measurements seem off.
    I never thought of it as 6x6 :duh:
    Anywho whever you buy the resin tell them your measurements!
    -aaron
  17. tkh
    tkh Minimodder
    1 Mar 2006
    Have a look in halford, Im shure they had some clear expoxy.
  18. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
  19. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I doubt it. This thread is 1,5 years old... :duh:
  20. modgodtanvir
    28 May 2007
Thread Status:
