Modding Cold Cathode Inverter: Where do you hide it?
Discussion in 'Modding' started by Cicada, 14 Apr 2003.
  1. Cicada
    Cicada What's a Dremel?
    29 Nov 2001
    im gonna build a new computer soon, and was jsut wonder where you guys put the power inverters for the cold cathodes :/
    i have 4 in my case right now, and they jsut sit there on the bottom of the case looking ugly :sigh:
  2. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I've grown fond of gutting and stuffing old CD Roms with electronics I don't need to access often and mounting them in unused drive bays. (of course without allowing the fce to show through the front)
  3. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    I am placing mine under the HDD rack, so it won't show through the window.
  4. Morphine
    Morphine weeee!
    23 Feb 2002
    I duct tape mine to the roof of the case :thumb:
    Oh and I need to buy some zip ties and zip tie anchors. All the electronic wiring not visible is duct taped to the sides of the case.
  5. blizzard
    blizzard tidy wiring d00d
    19 Oct 2001
    Inside the PSU! I have 3 inverters and a 4" ccfl inside my psu. Ofcourse I did cut all those stupid cables out :p
    -bliz
  6. bren2
    bren2 What's a Dremel?
    27 Jan 2003
    for me would be under my cdrom
    it worls fine and keeps cables to one side
  7. Cicada
    29 Nov 2001
    thats a very good idea :eek:
  8. Fatboy
    Fatboy Bored
    8 Oct 2001
    Its a good idea unles youve got a cheiftec/antec/whatever then the drive shell has to be fixed with the mounting rails, and you cant cover that witha blanking plate
  9. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Bought two cathodes a while back that came with inverter cards. Each one could power two cathodes, and had a sound sensetive mode with a sensetivity dial. Both cathodes arrived snapped in half, and the replacements were standard mitron cathodes. Oh wekk
  10. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Mount them in a little transparent box on the bottom of your case, with powerleds attached to them. Should be looking lots, and I mean LOTS nicer :D
  11. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    In maplin you can get these little plastic project boxes round about the size of a deck of cards but a little thicker. These are good for hiding 1-3 inverters. They come in many dif sizes.:jawdrop:
  12. bren2
    27 Jan 2003
    yer we have those in Australia they are called Jiffy boxes :)
    but yer u could fit heaps of them in one of those.. and depending on size will fit in a cd rom spot.. that would look neat
  13. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    I have four ccfls. 2 inverters hidden the top of the case and 2 others hidden in the drive cage.
  14. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    considering mine is 1 x 3 cm, i dont know how i could hide it much...usually just mount it to the bottom of the case...
  15. OneSeventeen
    3 Apr 2002
    Hehe, crap, I didn't even think of that!
    I haven't had to stuff wires yet in my new case, which happens to be an Antec!
    But with how big it is, I just stuff things behind that plastic thing that holds those really long cards I haven't seen in forever... (too lazy to take it out)
    You could also make larger feet out of plexi for your case and put an inverter in each foot, along with some LEDs... (not really a serious suggestion, but I wanted to stay on topic :D)
  16. ouija
    10 Nov 2002
    I'm sure you could mount it further back in the rails, I think with my cheiftec I needed to mount the optical drives as far back on the rails as possible... drill new holes? :sigh:
  17. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    was thinking the same, u cant stealth drives with the normal rails as u cant get the drives far enough back, will have to drill :/
  18. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Is that a screen grab of the new Matrix Reloaded trailer as your desktop pic ?? :p
