Windows Command Line
Discussion in 'Software' started by phenomx3, 26 Oct 2004.
  1. phenomx3
    phenomx3 What's a Dremel?
    4 Oct 2003
    I have command line application but to run it you need to access it from a command prompt. Can I create a shortcut so I click it and the program is accessed from the command prompt?
    Thanks
  2. buzzy
    buzzy What's a Dremel?
    27 Dec 2003
    Yeah, you can create a shortcut that runs CMD.EXE (the command prompt) and runs a program inside the command window.
    Right click on the desktop -> New -> Shortcut. The shortcut target should be:
    C:\Windows\System32\CMD.EXE /k C:\myprog\program.exe
    Cheers
    Buzzy
  3. phenomx3
    4 Oct 2003
    That is exactly it! Thanks. I have searched for that solution months. Thanks so much! I was thinking I would have to decompile the program and do some good old 'phenom' coding on it. Fortunately it never came down to that so thanks again
  4. buzzy
    27 Dec 2003
    no worries :)
  5. phenomx3
    4 Oct 2003
    Another q lol. In DOS something like Program Files is written as Progr~ or similar. How would I know what a directory like ' Phenoms Folder 2004' would be, i.e. what is therule.
    Thanks!
  6. trigger
    trigger Procrastinator
    22 Mar 2004
    First six letters, then a tilde and a number, so:
    Program Files -> progra~1
    My Documents - > mydocu~1
    Phenoms Folder 2004 -> phenom~1
  7. mushky
    mushky gimme snails
    24 Mar 2003
    8.3 digit DOS compatible filenames.
    If you also had Phenoms Folder 2005 (or anything wiht phenom at the start but coming after alphanumerically), it would be phenom~2
