Build Advice Component selection - need some help!
Discussion in 'Hardware' started by averageidiot, 21 Nov 2012.
  1. averageidiot
    averageidiot What's a Dremel?
    21 Nov 2012
    Going to finally be replacing my q6600 rig she has served me well but time to retire the old beast!
    Im looking for something a bit smaller this time i currently have a i3-540 knocking about i'm looking to use as well as my old PSU
    was looking to use a bitfenix prodigy case assuming i can find the relevant sized motherboard that will accommodate the I3 so that just leaves 4gb of ram and a mid range graphics card. i have the rest eg motherboard etc.
    so looking for recommendations for motherboard, ram, and graphics card!
    Regards:thumb:
  2. RocketPotato
    RocketPotato What's a Dremel?
    4 Sep 2012
    P8Z77-I Deluxe ;)
  3. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    itx or mATX?
    Budget?
    What games do you want to play or software you want to use?
    Please help us help you :D
  4. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    Unfortunately the motherboard RocketPotato suggested (P8Z77-I Deluxe) will not fit the i3 540; it's an LGA1156 chip while the board only supports LGA1155 chips.
    Scan is selling this board at the moment which suits your requirements perfectly.
    http://www.scan.co.uk/products/inte...d-sata-pcie-20-(x16)-graphics-on-board-mini-i
    However, performance wise I doubt you'll be satisfied by how much of a "beast" the i3 540 is since its performance compared to the Q6600 is close to being parallel to each other or even worse in some cases D:
    http://www.anandtech.com/bench/Product/53?vs=143
    My suggestion? Take RocketPotato's P8Z77-I Deluxe and slap a i5 3570K on top, finish it off with a closed-loop CPU cooler and you'll be happy for a good few years :)
