Small Form Factor Confused about RAM
Discussion in 'Hardware' started by JonDixon, 27 May 2004.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Okay,
    Im looking at either a 200N or the Shuttle SN45G
    Specs are looking like a barton 2500 to 2800
    120GB IDE HDD
    9600XT card and separate hauppage TV card
    or
    9600PRO all in wonder
    Im after 512MB or (1GB preferred although may not be possible due to cost) ram to go in these. Obviously I want dual channel but Ive read that some SFFs are fickle when it comes to brands.
    So can anyone recommend good ram to go in the Biostar and the Shuttle. Im not looking to pay the earth as I doubt I will be overclocking.
    I just want good performance ram. Any help appreciated
  2. Guest-16
    Guest-16 Guest
    I can only say from experience that the SN41 is fickle with my Geil PC3200, but the SN45 wasnt a problem. Cant speak for other brands though.
  3. da-dude
    da-dude What's a Dremel?
    11 Mar 2004
    i got bindis old geil in me sn45g, absaloutely no problems whatsoever even with the overclock and high temps
  4. calnen
    calnen moo!!
    2 Oct 2003
    If you're not overclocking, I'd always go for crucial. (The stuff does exactly what it's meant to, and they guarentee to always take it back if it doesnt.) Relatively well priced too.
  5. schmitty511
    schmitty511 What's a Dremel?
    26 May 2004
    I have a sn45g shuttle and I started by trying to use kingston memory but it didn't work (i think the memory was bad) so then I bought some crucial and it has been running great ever since. :rock:x
    __________________________________________________
    AMD "Barton" 3000+, 512MB PC3200(Crucial), 2 40GB HDD's
  6. Nieko
    Nieko What's a Dremel?
    21 Apr 2004
    I dropped in Corsair TwinX PC3200 and never had a problem.
  7. Guest-16
    Guest-16 Guest
    O, there u are then :)
  8. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    corsair tends to work well in shuttles :thumb:
    not sure about the biostar, but sudhian may well be helpful for that though.
    RoB
  9. verse
    verse What's a Dremel?
    28 Mar 2004
    Ditto.
  10. da-dude
    11 Mar 2004
    yer, hi........ :eyebrow:
  11. JonDixon
    12 Mar 2002
    Thanks guess its between corsair or crucial.
    Now to pick a shuttle or biostar.
    Difficult - was leaning towards 200N but have read issues past 2 days about whining noises, so now more back towards SN45G
  12. Guest-16
    Guest-16 Guest
    I was referring to your comment on the ram :rolleyes:
  13. da-dude
    11 Mar 2004
    o lol, forgive my dumbinessess :wallbash: :wallbash:
    go for the sn45g dude, quality is great - if you wana have 200fsb get the 2nd edition tho
  14. Penrhos
    Penrhos What's a Dremel?
    23 Oct 2001
    I always use crucial or corsair in Shuttles as I've had big problems with cheaper stuff "Geil" , "major brand" in SN41's the SN45 isnt so fussy as it hasn't got the builtin video. There is the V2.0 m/b problem where if you mess with Vdimm the boards can just stop working but overall I've not had any problems.
  15. JonDixon
    12 Mar 2002
    Yeh ive heard that on the v2, but apparently the new bios disables changing the vdimm setting
