Case Mod - In Progress Cosmos S
Discussion in 'Project Logs' started by skullen, 9 Jul 2011.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Hi all not been on for a while.
    My next build will be a Cosmos S nothing to posh just a bit of work here and there.
    Keeping cost down a bit i will be using some bits from my last build (white lian li 343b) and some new bits and yes im a tight old git.
    I like the colour of the case so will be keeping the grey with some white thrown in maybe another colour but not sure yet.
    First bit was to spray the mesh bits white and the bars
    To keep the cost down i also swaped the two panels over instead of getting a new panel for the window side.
    I used this idea from another forum .
    I wont be using the big fan on the panel just the mesh which i sprayed white also.
    Cut some card for window see how it will look
    Decided to paint the grills
    Acrylic was cut to size then i did a bit of drilling and cutting and test fitting
    Rear with grill fitted
    Floor bit done
    M/Board and front covers done,pump and res for a test fit.
    Still got a few more bits to do and some more bits to turn up.
    Thanks for looking. :thumb:
  2. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I knew you had another build up yr sleeve Ian! :D Should be another show piece when you're finished :thumb:
  3. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the reply Bill,much appreciated :thumb:
    Few more pics
    Stuck a couple of blue fans in for now might go with these or i have some white ones coming.
    Got some EC6 blue fluid so i will have a play with both sets of fans to see what looks better and hope to light up the fluid.
  4. catsol75
    catsol75 What's a Dremel?
    2 Mar 2010
    What res is that matey
    - Phil
  5. skullen
    skullen Minimodder
    31 Oct 2007
    Hi Phil,its a Danger Den Rad Res :thumb:
  6. catsol75
    2 Mar 2010
    cheers - looking good so far
  7. skullen
    skullen Minimodder
    31 Oct 2007
    No probs,thanks :thumb:
  8. bulldogjeff
    2 Mar 2010
    As I was reading down I was thinking the exact same thing.
  9. Stem83
    Stem83 Addicted to modding.
    26 Mar 2011
    great start..
  10. skullen
    skullen Minimodder
    31 Oct 2007
    Thanks for the replys,much appreciated :thumb:
    Small update,new fans
    Fitted and testing
    Made some standoffs from rad spacers
    Test fitting some more fittings
    Hope to do some more at the weekend.
    Thanks for looking :thumb:
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Like that setting up of the pump and res - so I subbed.
  12. skullen
    skullen Minimodder
    31 Oct 2007
    Cheers Nutman :thumb:
    Some more shiney bits,XSPC Delta block with a sli fitting to join the block and chipset gonna change the nut fttings and get some nurled ends.
    Also gonna have a go with some shower hose over the tubing
    Had some 11mm tubing laying around and it fits in the hose
    Had a play with the hose and some fittings dont look to bad still needs a bit of work but i think i can make it work with some fittings ive seen
    Also got my grill done
    Will paint this soon,thats where i am at the mo build is a bit slow.
  13. bulldogjeff
    2 Mar 2010
    All looking very neat and tidy so far. I like the shower hoses as well, looking forward to seeing this one develop...Nice work.
  14. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Cosmos S is such a classic case, wonderful for modding.
  15. skullen
    skullen Minimodder
    31 Oct 2007
  16. Nutman
    21 Oct 2008
    Like the shower hoses, but always wondered how hard they are to cut and how you're gonna get them sticking as close as possible to the fittings through time?
  17. bulldogjeff
    2 Mar 2010
    The plastic ones are easiest to cut, but the metal ones look better and are way more flexible. Plus they won't kink.
  18. skullen
    skullen Minimodder
    31 Oct 2007
    Almost there got it up and running seems to be ok
    Still got to put acrylic in the panel and a couple of other bits and bobs.
    Pics so far.
    Thats where i am at the mo im happy how it looks :D
  19. Nutman
    21 Oct 2008
    Hey, where did the shower hoses go?
  20. mnpctech
    21 Apr 2003
    another awesome build Ian! love the interior :thumb:
