Modding cpu to power button
Discussion in 'Modding' started by digitalattrition, 5 Jan 2004.
  1. digitalattrition
    digitalattrition What's a Dremel?
    5 Jan 2004
    is there any way to mount a dilapidated CPU on the outside of the case to become the power button?? it seems like a good idea...
  2. The_Sub
    The_Sub What's a Dremel?
    16 Nov 2003
    Use a hot glue gun and put a dab on the cpu then place it on the switch. It'll be raised quite a bit from the normal switch but would work.
  3. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    like he said, it would be as simple as mounting the old cpu to the switch.
  4. digitalattrition
    5 Jan 2004
    my power switch is sunk into the case a bit and there is a bit of plastic surrounding it. i suppose i could sand it down flush with the power button or cut some material out and then attach the cpu?
