Modding Crazy Custom Mouse idea
Discussion in 'Modding' started by _rahoul, 2 Jun 2004.
  1. _rahoul
    _rahoul What's a Dremel?
    5 Apr 2004
    :idea:
    I just recently destroyed my MS Intellimouse Explorer v3, which has since been replaced with a MX700. Now, i managed to destroy the actual casing and buttons of the mouse, not the internals/base fortunately so its still functional just not really usable.
    So im thinking is there a way that i could make a 'shell' that would be totally custom moulded to fit my hand? This shell would then be attached to the base of the broken V3 mouse, giving me an incredibly comfartable mouse. Perhaps plaster of paris or some such thing would work.
    Any ideas?
  2. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Buy a new mouse.
    http://server5.uploadit.org/files/jeffrey9-theone.jpg
  3. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    Try to get hold of some of that prototyping plastic that melts in hot water, mould it to your hand, then let it set and smooth it down etc. when it's like normal plastic!
    Plaster of paris would be very difficult to work with i imagine, and probably be quite heavy...
    They do plaster casts from carbon fibre type material, it's like a mesh of plastic wire they dip in hot water and then let it set, you could look into that... it would need filling in with filler to get the smooth finish you'd want.
    *shrug* :)
  4. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    I doubt plaster of paris would be too heavy for everyday use - i.e internet use or work but if you're gonna be gaming then it might be a bit unwieldy IMO.
  5. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    i would use plaster of paris only to make the mould of the mouse...
  6. _rahoul
    5 Apr 2004
  7. Sniper-X
    Sniper-X What's a Dremel?
    27 Mar 2004
    what about making one up out of fiberglass matting ?
  8. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    If I were to do this, I would either sculp one out of clay to my likings then make a negative image in a mold. Or just make the negative of my hand in plaster. Then you could possibly use fiberglass or something similar in the negative image mold, to make a thin shell for the mouse.The hard part would be making the buttons covers that move freely. Really though I find most of my mice comfortable, its more wrist position
