Hey guys, Yet another case mod from my, I'm working on 3 at the moment. This one is in the Thermaltake View 27 case. Iit will be Watch Dogs 2 themed and I'm calling it ctOS Tower 27. I did an overview of the case a few months back. You can check it out below: SPECS Case - Thermaltake View 27 CPU - Intel Core i7 6700K MB - ASUS Sabertooth Z170-S RAM - 4 x 4GB Kingston HyperX Predator 3000MHz DDR4 GPU - NVIDIA GTX 1070 Founders Edition SSD - 2 x 240GB Kingston HyperX Savage HDD - Seagate TBC PSU - Thermaltake Thermaltake DPS G RGB 650W Custom cables & lighting - CableMod Water Cooling - Thermaltake I'll start this one as well with some photos of the case: Thanks for checking it out and stay tuned for more! Cheers, Alex
Hey guys, Here's the first update I made a cut out in the PSU shroud and added some acrylic cover panels. Next step is to add all the graphics. The cut out will serve to illuminate through the bottom acrylic panel once the graphics are applied. Thanks for checking it out and stay tuned for more! Cheers, Alex
Hey guys, I have some pretty cool hard tube fittings to show you The Thermaltake Pacific RGB fittings! I did a video on these a while back and only getting around to using them now. Thanks for checking it out and stay tuned for more Cheers, Alex
Hey guys, I have an update on the work I've done on the fans and SSDs. This will give you more of an idea for the theme and the vinyl that I'm using Thanks for checking it out and stay tuned for more! Cheers, Alex
As the fans and SSDs, I added a similar skin to the ASUS Sabertooth Z170S motherboard BEFORE AFTER And same with the pump/res combo Stay tuned for more guys Cheers, Alex
