Memory DDR3 dimms?
Discussion in 'Hardware' started by Harlequin, 11 Jun 2024.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    So a random question - does anyone know of any 16GB DDR3 Dimms; ECC but unbuffered (eg non registered).
    Struggling to find any info let alone sticks!
  2. Vault-Tec
    30 Aug 2015
    I’d imagine saspro would know the answer to this.
    Harlequin likes this.
  3. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    IIRC Non-ECC Dimms topped out at 8GB because Intel consumer chips only supported up to 8GB. ECC Reg 16GB sticks are everywhere because Intel enterprise and AMD supported ECC Reg and up to 16GB per stick.
    Harlequin and Vault-Tec like this.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    THis is the correct answer.
    8GB is the max you'll get in DDR3 ECC Unbuffered
