Cooling Dry ICE
Discussion in 'Hardware' started by bamboo, 27 Jan 2007.
  1. bamboo
    bamboo What's a Dremel?
    4 Nov 2006
    Sorry because my English is bad. So pictures more than words :D
    This is my first Container.
    Outside
    I dig a furrowdrain to hide wire of sensor.
    Inside
    My digicam very hard to take photo near the container.
    Install sensor wire
    Sensor wire under drain
  2. bamboo
    4 Nov 2006
    Some overclock result
    Specs
    CPU: Core 2 Xtreme X6800.
    Mainboard : P5B-Deluxe.
    Ram : Micron 512x2
    Dry Ice: 2kg.
    Bios set: Vcore set 1.65v.
    Vram 2.4v
    Temp in bios is -47*C
    Temp in Bios [/B]-47*C
    Result : 2.93@4.4Ghz
    Ai suite can't record temp
    SpeedFan -28*C
    Super Pi 1M
    2.93@4.488Ghz
    Super Pi 1M
  3. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    Im no sry-ice expert, but wow! This looks pretty god for a first build. Congratulations!
  4. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Very nice for your first attempt, any pictures of it in action?
    EDIT: I can't really find any fault with what you have there.
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Check seating mate, temp looks a little on the high (low?) side for DICE. Tube could also be overfilled/no Acetone? What sorta base temps were you seeing?
    Otherwise, nice work. Tube looks great.
  6. Guest-16
    Guest-16 Guest
    Seems like it's just containing DICE, which would make it around that -30C temp range. You need some acetone or ethanol to fill in the gaps and really drop the temp down. Acetone will give you -80C.
    Tube does look like a fantastic bit of engineering :thumb:
  7. K404
    K404 It IS cold and it IS fast
    11 Sep 2006
    http://en.wikipedia.org/wiki/Carbon_dioxide
    You`ll never see -80 under dice with any kind of heatload
    Dice quality, thermal losses and 100W+ heatdump will make sure of that. You`re unlikely to even see it idle
    : original post...nice! some nice touches in there :) I have to say though, -47 in BIOS seems a bit off. You should see -63 ishhh ideally (with acetone)
  8. Highland3r
    25 Jul 2003
    4.7ghz (afaik) with just over 1.8vCore.
    Probe temps (base of CPU tube) @ 4.7ghz (1.8vCore) CPU @ idle. Load saw temps dip to ~ -70 or so tube base temp.
    Probe stuck in box of DICE. That's about as low as you'll ever see DICE, it sublimes @ ~ -78.
  9. bamboo
    4 Nov 2006
    Yes, i wrong when i make base only 30mm diameter. it very small, i think too small to transfer heat.
  10. Highland3r
    25 Jul 2003
    What sort of base temps did you see?
  11. fatty
    fatty Minimodder
    12 Jul 2004
    My X6800 was running mid -70's full load under the cascade 1.84V 4.8 gig but the compressors were hot and it didn't like finnishing benches :(
    Bios shot at idle ( bios shows 1.6someat volts but the mobo was vmodded actual volts 1.84 ish )
    Fluke at idle
  12. Guest-23315
    Guest-23315 Guest
    i think i should make use of the CNC lathe we have at school and make a 3" pot.
  13. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    omg soo cool
    quite literally
    nice jobs
