Windows dual boot xp and vista issue
Discussion in 'Software' started by cannon, 18 Feb 2007.
  1. cannon
    cannon What's a Dremel?
    15 Jan 2004
    Howdy,
    I am trying to install windows vista business on my home PC dual boot with xp and vista.
    First off the hardware in question is AMD 5200+ , DFI LP NF590 SLI M2R/G, OCZ DDR2 PC8800 GOLD Dual Channel , HIS x1950xtx, Zalman 600w Heat Pipe PSU, Dual Samsung Spinpoint SATAII 400Gb, HP SATA DVD Burner.
    I currently have xp pro installed and wanted to dual boot to make sure i was happy to go ahead with vista. I have created a 25GB primary partition. I have then inserted the disk in windows, ran through the setup telling it to install to my new partition (v:).
    It copys the files then about 25% through unpacking it restarts, if i run through the boot loader and select windows setup it get to the progress screen and just sits there. If I restart the pc (hard restart) it will run through the progress bar about 3.5 times then stops mid way - doesnt do a thing.
    I have also tried booting directly from the install disk (DVD), when I hit any key it does the same thing - gets to the progress screen and just sits there.
    If i fire XP back up it tells me it was unable to install vista and to check compatibility but the upgrade adviser gives me the all clear. I have a feeling i cant boot directly off the disc cause its a sata dvd drive but not sure if this is effecting the standard installation aswell.
    Have played with the OS on a mates laptop and was impressed, didnt think a dual boot would be so hard.
    Thanks in advance.
    Paul
  2. cannon
    15 Jan 2004
    Read a bit on this, planning to kill the overclock and run the vista memtest to see if it makes any difference.
    Anyone knows about this?
    P
  3. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    This might not be helpful, but I did exactly what you did:
    - partition magicked the drive for a new primary partition, in my case 125gb
    - booted into XP, popped the Vista CD in the drive
    - clicked install
    - left it for about 20 - 30 minutes
    - set my language settings
    And I'm done. Maybe a faulty disc or hardware error? Certainly doesn't sound like software or anything you're doing wrong...
  4. cannon
    15 Jan 2004
    Problem is everythings brand new and runs like a dream in xp but ive since read its very picky about its ram so will run the memtest thing built into it and try again - maybe it writes something somewhere to says its successful and will go from there, otherwise ill turn off the overclock.
    My dramas start when it first reboots ~30% through unpacking.
    Cheers
    Paul
  5. cannon
    15 Jan 2004
    ok - its up - on vista now - doing the memtest thing did nothing - was successful but didnt help.
    removing the overclock did :(
    see how we go - may try to push it back up now its on and see what happens.
    Paul
