Peripherals Easy to paint keyboards?
Discussion in 'Hardware' started by TheGreatSatan, 16 May 2013.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Any keyboards that are easy to take apart and paint? Most fall to pieces when I take 'em apart
  2. GeorgeStorm
    16 Dec 2008
    Which bits are you wanting to paint?
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    just about any mechanical keyboard will be alright - i take mine to bits all the time, i mean literally, into all the pieces :)
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Without hijacking this thread any links to sites that explains how to strip a mech board for painting?
  5. TheGreatSatan
    5 Aug 2005
    Just the outer shell, not the keys
  6. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Cherry G80-3000 is nice and easy. The shell clips together with huge hard to break tabs, not even the PCB has screws just friction fit. Unless you want some unique finish, using vinyl dyes is more recommended than regular paint for durability.
  7. GeorgeK
    18 Sep 2010
    A mechanical keyboard was my initial thought too & I would go for a 'cheaper' mechanical keyboard too (like the g80-3000) so there's less to lose if you stuff it up...
    How to dismantle the board would vary depending on the board itself. Most are fairly simple with a couple of screws (or maybe none) and plastic tabs that hold the top shell to the bottom - I find sliding a credit card between them helps to pop open the casing...
  8. Shirty
    18 Apr 1982
    Or if money's tight, presumably a G83-3000 will be largely identical in terms of disassembly?
  9. Kronos
    Kronos Multimodder
    6 Nov 2009
    This question has got me in the mind to paint a mech keyboard also. Damn you TheGreatSatan. No sure I wany to pull apart the ones I have though. need to be on the look out for a cheapie.
  10. longweight
    7 May 2011
    What board might you open up to paint?
  11. Margo Baggins
    28 May 2010
    It's honestly EASY to open up mech boards.
    I use credit cards also to pop the top shell from the bottom. I'm pretty heavy handed, I've not broken anything yet. My keycool I think i've had the top and bottom shell apart about 20 times at least, and the top still fits back on the bottom as well as it did when I got it.
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    I might just have a go at my CM Rapid Fire then as that was the cheaper of my two boards. Will need to think about it and decide on a colour as I have red and white keys on it just now.
  13. jaydeee
    jaydeee What's a Dremel?
    25 Apr 2010
    Most of logitech keyboard can dissembled then repainted...
