Case Mod - In Progress Enigma - TJ07, SLI, 3 loops, Laser Cutting, Powdercoating + Etching
Discussion in 'Project Logs' started by marcus000, 1 Mar 2008.
  1. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
    Thought it was about time to drop this bombshell on here so here we go!! :clap:
    Hardware:
    XFX 780i Motherboard
    Intel Q6600 (G0 Stepping) - possibly upgrade to Yorkfield
    4GB OCZ Reaper (2x2GB)
    2 x 8800GT 512mb - NO LONGER GOING FOR TRI SLI
    Enermax Galaxy 1KW PSU
    Soundblaster Fata1tly
    2 x 150GB Raptors in Raid 0
    Watercooling
    Loop 1
    CPU - EK Supreme OR D-Tek Fuzion
    Northbridge - AF Custom Block
    Mofsets (2) - AF Custom Block
    DDC Ultra with EK Top
    Thermochill PA120.3
    Loop 2
    GPU's (2) - EK Full Cover Blocks
    Black Ice Stealth 360
    Loop 3
    Ram - MIPS Ram block + AF Custom Top
    HD's - Danger Den Dual Drive block
    Southbridge - AF Custom Block
    XSPC X2O Compact 400 Pump / Reservoir Combo
    XSPC R120-S Radiator
    Case: Silverstone TJ07
    Mods:
    Internals powdercoated black
    Externals powdercoated orange (RAL 2009) + Lacquer
    Laser cut side panels
    Cable braiding (ARGH!!)
    Somehow cramming in 3 loops!
    Some funky acrylic and LED fun :D
    Part 1 - Hardware
    Scan finally game through with the goods :shock:
    2 x WD Raptor's
    SATA DVD-RW
    Some of the watercooling parts
    More to come as soon as the GFX cards arrive.
  2. marcus000
    7 Aug 2007
    Part 2 - Case Mods
    I have got all the case internals back from being powder coated, not much to see as it's currently in bits.. can't put it back together until the outer case has been coated!
    Don't think I posted a pic of this before I took it to get coated but basically this is the middle divider than runs through the case.
    Originall it was split into 3 smaller sections so I whipped out the dremel out made it into one big area, the black acrylic false floor will cover this up afterwards :)
    UPDATE - Side Panel Lasering and Etching
    UV Red Acrylic etched with Enigma Guild logo and moto
    I still havent mastered how to photo the etching but was speakin to Richi on MSN earlier about it. When I get the panels back I will try out some different methods to get clearer shots.
    These 2 were took with flash on, not sure why the flash cancels out half of the etch though.
    UPDATE - Braiding
    Here we have the mCubed T-Balancer and the add on Sensor Hub... and that means a hell of a lot of cables, so out came the braid on them! Took me a while to do, nearly 20 wires in total!
    XSPC Pump - DONE
    Front Panel Power & Reset Switches and LEDs -DONE
    Front panel connectors heatshrinked, had to order some larger stuff in for some of the Audio wires hence delay in getting it done.
    2 of these pumps are for this build and the other 3 are for another called Supernova
    DDC Ultras with EK Tops - DONE
    UPDATE - LED Fun
    Ordered a load of LEDs, some white and some UV. The UV ones will be used to Illuminate the side panel and white ones to illuminate the case internals.
    In the pic below you can see about 50 White LEDs with 560Ohm resistors soldered onto the positive leg and then heatshrinked over.
    Made the stealthy LED floor with a piece of scrap black acrylic, test run before I do it with the proper piece.
    This should illuminate the motherboard area nicely without being too in your face like cathodes can be. :)
    Think I saw it done on Bit Tech many moons ago, liked the idea ever since.
    5/16" holes drilled 40mm apart, 20mm from the edge:
    Got some of these nifty little LED holders to go in the holes (those are the 5mm white LED's that I spent hours soldering resistor to btw)
    With the nifty holders in place:
    Few LEDs wired up with crocodile clips whilst I made sure eveyrthing is looking ok
    I'm still tinkering with those LEDs right now, and also trying to find a way to incorportate a light controller to dim them down when need be.
  3. marcus000
    7 Aug 2007
    UPDATE - Externals Powder Coated
    Case back from being powder coated, RAL 2009 + a clear coat as well.
    Lighting isn't brilliant on the pics but its pouring with rain at the moment so proper pics will have to wait till tomorrow. :D:D:D
    Just to put anyones mind at rest regarding the colour, these pics below are much more true to life, the others show a very pale shade of orange.
    Still need to sand down some bits to get the case to fit back together nicely together but this is where i'm at, at the moment....
    Got some black thumbscrews as well somewhere.
    UPDATE - Fan Wiring
    Black Ice Stealth 360 fans all wired up together
    Thermochill PA120.3 with daisy chained Xilence Red Wing Red LED Fans
    Fan on XSPC R120-S radiator braided and 3 pin connector soldered
    Also still waiting for the Matrix Orbital LCD to arrive, Murderbox style I think.
  4. marcus000
    7 Aug 2007
    Reserved for watercooling pics - Still waiting for blocks from Germany to arrive, should be here within the next day or so.
  5. marcus000
    7 Aug 2007
    Grand finale
  6. jhanlon303
    7 Sep 2006
    Another Orange and Black mod!!!!!!!!!!!!!!! You guys need to quit teasing me with my favorite colors:thumb:
    I'll be watching
    John
  7. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    5 PUMPS!!!:jawdrop:
    i love you:blush:
  8. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    Yay for gaming guilds and clans. ;) Looking great, Marcus. The color scheme pops and the cooling loops planned are very ambitious. I can hardly wait to see it all together with the lights on.
  9. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Awesome, my case is black and orange too! (CM Stacker) ;)
    Continue! :D
  10. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    that looks really good :thumb:
  11. Tolk
    Tolk Keep it simple, build it incredible
    7 Feb 2008
    dang! That is looking seriously sweet!
    Love the powder coating!
    and wow on that mb tray.. looks awesome!
    Great job so far man.. doing the Enigma name Justice :D :thumb:
    -Tolk
  12. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    WOW! Nice! 3 loops! Amaizing!
  13. Guest-23315
    Guest-23315 Guest
    Awesome colour combinations...
  14. tolis86
    tolis86 What's a Dremel?
    3 Nov 2006
  15. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    the color scheme looks awesome ......... :thumb:
    .....I don't want to sound negative,but for it being clear coated
    it does still seem to have a visible orange peel effect to it.
    Will you be wet sanding it to get rid of it?
    3 loops.......will each loop have a different color?
    Alan
  16. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    Lovin' the color combination :)
    Too bad the main window is a bit boring.
    Apart from that, niiiiice work!
  17. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    That color scheme made me go wow, that orange is amazing :)
  18. marcus000
    7 Aug 2007
    lol im guesing you didn't read the text above the pic, 3 of those Ultras are for another build called Supernova, I was just braidin them all at the same time. :idea:
    Yup as you casn guess, the customer runs a gaming guild.. think its based on that Age of Conan game, i'm not sure off the top of my head. :thumb:
    Yeh I can see what your saying, compared to the black and white powder coating i've done previously this one does have more orange peel than the others (I even had a hell of a lot of people sayin that the white looked almost like paint, it was that good).
    I was talkin to a friend about it last night who does paint jobs everyday (protoype designer) and he talked me through the wet sanding & polishing process as he commented on that as well. The outcome was that i'm gonna powder some spare side panels and practice on them so that next time I will have some experience in doing it, I don't fancy practicing on a £200 case.. especially not when it's for a customer.
    3 loops - All Feser 1 Black but with different shades of primochill coils one, orange, bright orange and red.
    Not much to report yet but I just daisy chained the fans on the Black Ice and Thermochill radiator:
    These will all be powered off the T-Balancer :thumb:
  19. perkins teh modder
    8 Dec 2007
    i read tat you were only using 2 for this build, but i was just suprised that you have 5
  20. marcus000
    7 Aug 2007
