Linux Execute program at boot time with Gentoo
Discussion in 'Software' started by simon w, 30 Apr 2004.
  1. simon w
    simon w What's a Dremel?
    3 Nov 2003
    I've just emerged (you gotta love that program :rock: ) a program called numlockx. How would configure Gentoo to execute this program at boot time?
  2. jcm44
    jcm44 What's a Dremel?
    4 Feb 2002
    Read the Gentoo FAQ it will answer your question perfectly.
    BTW - The FAQ under Docs
  3. Uncle Psychosis
    Uncle Psychosis Classically Trained
    27 Jul 2003
    There are lots of different ways of doing it. You could add the line
    to your .xsession, or you could add it to the default runlevel (Which isn't the way I would do it). I would check out the Gentoo FAQ and also the forums on gentoo.org, which are damned good :D
    Sam
  4. simon w
    3 Nov 2003
    Sorry, sorted this a while ago. Adding numlock to rcupdate, both as default and boot, half worked. Num lock was on at run level 3, and was also turned on when I ran startx, but then it turned itself off whilst loading X/xfce...
    I found that placing a shortcut to numlockx in /home/simon/desktop/autostart (?) worked :thumb:
  5. Uncle Psychosis
    27 Jul 2003
    Ahh, sounds like you have a WM that makes it nice and easy for you. I'm guessing you're using KDE or Gnome? I'm more of a fluxbox man myself!
    Sam
  6. simon w
    3 Nov 2003
    Nopers, I'm using xfce :clap: I prefer it to kde & gnome
  7. RTT
    RTT #parp
    12 Mar 2001
    I recently moved to XFCE from fluxbox and haven't gone back :D
  8. Uncle Psychosis
    27 Jul 2003
    OOoh...I've been thinking about doing that. What did you have to do?
    emerge xfce, then change the xinitrc? Anything else? Or am I talking baws?
    Sam
  9. simon w
    3 Nov 2003
    I think I just emerged xfce and then set the XSESSION variable
  10. Uncle Psychosis
    27 Jul 2003
    Ahh, ok. Well it seems to be working. I fiddled with my .xinitrc a bit too!
    Sam
  11. simon w
    3 Nov 2003
    *Simon goes off to learn what .xinitrc is all about*
