Displays Extra Monitor connection options
Discussion in 'Hardware' started by blacksta, 7 Aug 2012.
  1. blacksta
    blacksta What's a Dremel?
    1 Nov 2011
    My current monitor connection is via a VGA cable and would like to add another monitor ( vga socket). My motherboard has has an extra hdmi and DVI slot and no graphics card. Please advise of a reliable connection mode.
    1. Is there anythng like a Hdmi to vga cable
    2. or DVI to vga cable
    3 Would i need to buy a graphics card
    Thanks
  2. Parge
    16 Jul 2010
    1. Is there anythng like a Hdmi to vga cable - nope - won't work
    2. or DVI to vga cable - Yes you can get an adaptor
    3 Would i need to buy a graphics card - what is your motherboard and CPU?
  3. blacksta
    1 Nov 2011
    thanks for the quick info -
    MB - Asus p8z77-v lx
    cpu - intel i5 3570k
  4. Parge
    16 Jul 2010
    The 3570k can support up to three displays. Just buy a DVI-VGA adaptor. Should cost about £1
  5. blacksta
    1 Nov 2011
    thanks - will do ,
    can you recommend any - seen some on amazon
  6. Parge
    16 Jul 2010
    This one will be fine. £1.07.
  7. blacksta
    1 Nov 2011
    Forgot to mention. It is a dvi-d slot and not a normal dvi - will the above recommendation still work
  8. faugusztin
    11 Aug 2008
  9. Parge
    16 Jul 2010
    Why not?
  10. blacksta
    1 Nov 2011
    Could it because it is digital signal. Are all lcd monitors digital ?
  11. faugusztin
    11 Aug 2008
    DVI->D-SUB adapters takes the DVI-A signals and convert them from DVI connector to D-SUB connector without any modifications. DVI-D doesn't have DVI-A connected, so you cannot use that adapter. You need DVI-A or DVI-I (which is DVI-A + DVI-D) for DVI->D-SUB adapters.
    In other words :
    http://upload.wikimedia.org/wikipedia/commons/6/65/DVI_pinout.svg
    DVI->D-SUB adapter needs the red pins, but DVI-D has only the non-red pins connected - take a look :
    http://upload.wikimedia.org/wikipedia/commons/f/fb/DVI_Connector_Types.svg
    @OP: What is the reason for not buying a LCD with DVI/HDMI port ? It's not like there is insane price difference between the lowend D-SUB only and lowend D-SUB+DVI displays.
  12. blacksta
    1 Nov 2011
    Thanks for breakdown. No particular reason , i was only trying to make use of the spare vga port lcd monitor i have at home and i thought i could somehow convert the dvi-d signal to vga signal
  13. faugusztin
    11 Aug 2008
