Electronics Factory Bells
Discussion in 'Modding' started by HACKSTAR, 21 Jun 2005.
  1. HACKSTAR
    HACKSTAR What's a Dremel?
    19 Jun 2003
    I have been asked to investigate a soloution for automaticall ringing a bell at break times in a factory. My first approach was looking at dedicated soloutions, with built in atomic clocks and lcds displaying the date and time. These are an expensive and overkill soloution. This got me thinking about relay cards.
    I have never really explored this area and this seems like a fun way to start.
    Could somebody reccomend a hardware/software soloution that would enable me to connect upto 4 bells to a serial/com/usb port and enable them at certain times of the day.
    I was thinking about something like this one at
    http://www.audon.co.uk/som1.html
    But not being familiar with the software don't know how easy it would be to schedule the bells.
    I would greatly appreciate any help or pointers you can provide.
    Cheers :D
  2. ARM
    ARM Minimodder
    15 Sep 2004
    Hi Hackstar,
    The link you were referring to is a commercial unit, I'm not to fimilar with it, but I would guess that would be what you are looking for.
    What I have is a diy solution using the parallel port. Most of the ideas are from here:
    http://www.epanorama.net/circuits/parallel_output.html
    See under the title:
    Compact 8 channel output driver
    and you'll find a simple example circuit using the ULN2803 chip. Subsitute the
    LEDs for relays and then link each of the bells to a relay.
    For software, see under the title:
    Ready made control software
    I use KemoM125 kit (Relais Timer). It's a simple software where you can program when each relay turns on and for how long.
    Hope this helps.
    ARM
  3. butch_vendor
    butch_vendor What's a Dremel?
    21 Jun 2005
    I can offer a few solutions to this, but I need to have an idea of the budget you have to spend. Personally I would try to avoid using a PC for this task.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I agree. Think about it, any cheap digital-clocked central heating controller can switch on twice a day to the second, some four times a day. It's easy to rig switch-on to a timed bell. How many breaks are there?
  5. bigal
    bigal Fetch n Execute
    8 Oct 2004
  6. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    One timer relay with presettable 1-10 second delay on power on.
    One electronic timer with 24 hour clock, days of the week and program points at least double the break ammount (on and off for each break)
    Or if you can find one, a 24 hour/7 day timer as above, but that can program seconds.
  7. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    use a sprinkler timer. I have one that cost me $30, and can be set for intervals as little as 1 minute, 4 times a day.
  8. Ghlargh
    16 Nov 2003
    A 1 minute long signal would be kind of annoying thou...
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A 555 one-shot would cut that time down for another $ or 2. One would be needed with most (cheap) commercial timer methods.
    Nice links, though, ARM :thumb:
  10. Wolfe
    7 Sep 2003
    but hey! its cheap, and prebuilt. Also, it can handle power outages (got a battery), and runs on 24 VAC, which is perfect for the bell.
  11. HACKSTAR
    19 Jun 2003
    Thanks Arm
    I have decided to give the circuit a try, just finishing it off now. I think this is the easiest soloution.
    Just out of interest why do people reccomend avoiding a PC for this?
  12. aka
    aka What's a Dremel?
    24 Jan 2005
    I doubt you'd find a commercially available atomic clock, which would be slightly overkill.
    Then again I doubt that's what you meant.
    Avoiding a PC seems like the best idea, unless you're also using the PC for something else that means it's left on all day.
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The workforce will be really peed off if there's a BSOD just before snaptime. :grr:
  14. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    it dosen't make sense to use a computer that costs £50+ to do something that electronics can do for £5 with change.
  15. HACKSTAR
    19 Jun 2003
    But if you have a room ful of servers, one of wich happens to be a time and attendance Server, then surely this is the answer coupled with the £1.50 circuit posted above.
  16. Wolfe
    7 Sep 2003
    You use a server instead of a timeclock?
  17. butch_vendor
    21 Jun 2005
    I work in industrial automation and I woudn't use the PC for this task. I would use a cheap PLC (Programable Logic Contrtoller) and sychronise its clock to the servers clock over a RS232 or ethernet connection. The key point in industrial applications is that the system is relaible and simple to modify. A basic PLC will start around £100.
    A PLC system would use a industry standard programming lanuage like ladder logic that any conrol engineer could modify at at later date. Whereas a bespoke system on a PC would require a software specialst to modify it.
    In the short term a PLC may apper to be more expenive but it has long term benefits.
  18. butch_vendor
    21 Jun 2005
    I would have a look at the Telemecanique Zelio range of smart relays. These are relatively cheap simple PLCs. They have inbuilt clocks and the programming software (ladder logic ) is free to download from thier website.
    Have a look at this link to the Zelio smart relay web site, on this you will find out everything you need to know about one.
    http://www.telemecanique.com/WEBKITS/Automation/ZELIOLOG/ENUS/index.htm
