Modding fan painting
Discussion in 'Modding' started by Guest-18698, 24 Nov 2006.
  1. Guest-18698
    Guest-18698 Guest
    how do you remove the centre fan blade out of the sqaure cage that its sat in? is there an easy way?
    also where can i buy some A.C.RYAN fans? 120 mm pref purple UV
  2. slytherock
    slytherock What's a Dremel?
    10 Jun 2004
    Take the fan face up
    push the blade into the cage
    While you push in turn it down, you'll see a little pin behind the motor
    remove the clip: be carefull not to lose this clip
  3. Guest-18698
    Guest-18698 Guest
    cheers dude!!!
  4. Guest-18698
    Guest-18698 Guest
    would you happen to know where i can get A.C.RYAN fans?
