Modding Fan Question
Discussion in 'Modding' started by digitalp1mp, 14 Dec 2003.
  1. digitalp1mp
    digitalp1mp What's a Dremel?
    19 Aug 2003
    Ok ive got a LIAN LI Case, and it has 2 Intakes, and 1 Exhaust, should i go ahead and make another rear Blowhole or go for a blowhole in the top of my case? And if i do make a blowhole up top, wut size fan would you reccomend? Thanks alot
    Chris^
  2. digitalp1mp
    19 Aug 2003
    Anyone?? Come on
  3. pez
    pez What's a Dremel?
    1 Nov 2003
    i think you should make a fan-hole in the back AND in the top..
    its better with many fans running at low voltage than few that runs on high voltage....
    as for the fan size: the bigger, the better. (better noise/airflow ratio)
  4. digitalp1mp
    19 Aug 2003
    so wut about another 80 in the back and 120 up top?
    thanks
  5. STellY
    STellY What's a Dremel?
    24 Aug 2003
    that sounds like a good plan...
    a nice big 130mm fan up top will help cooling SOO much
  6. digitalp1mp
    19 Aug 2003
    Ok ive got another question now, I have a generic 420 Watt PSU, with it be enough to run my system + 4cold cathodes and 5 fans? And 3 HDD's? I just got to thinking about this, because i wanna run all UV Fans, w/2 blue cathodes then flip the switch on for 2 more UV Cathodes. I think this would look really tight thanks for the help thus far-edit- i usually only have 2 hdd's working also.
    Chris^
  7. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    If you check the electrical specs on your hardware, they should have ratings on them so that you can work out roughly how many watts you're using??
    I know you can work this out and then allow for a percentage extra as a safety margin. and maybe one of the electical gurus out there can give ya more detailed advice about how much that safety margin should be??
    Good luck
  8. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    a 420wt psu is more than enough to run prettey much anything.
    it's when you start adding in crazy amounts of Hard drives n such that you need to consider some crazy wattage psu.
    Your psu is fine.
  9. Malvolio
    Malvolio .
    14 Dec 2003
    I run two optical drives, a gigabyte mobo, two 12" cold cathodes, 4 40mm LED fan's, 1 50mm cpu fan, 1 20mm video card fan, 2 hard drives, and a ton of LED's off of a generic 300watt psu, not a problem yet. My athlon XP 2100+ runs at 43c/109f, is that normal?
  10. Dazbo666
    16 Dec 2002
    Well I run a similar rig, but with XP2600 at 46-50c, so your setup sounds pretty good to me!
