Linux Finding out what hardware in linux
Discussion in 'Software' started by Slim Slotloader, 2 Mar 2007.
  1. Slim Slotloader
    Slim Slotloader What's a Dremel?
    19 Feb 2007
    A friend of mine has a three year old linux that might be used as HTPC.
    Problem is he does not know anything about the computer except it having a ASUS mobo. :rolleyes:
    He lives too far away from me to get over there and check it out, and i do not know linux at all :duh: to tell him where to find the specs.
    Is there, for example, some program similar to sisoft sandra, or could someone tell me an easy way to find out?
    Thanks
  2. trigger
    trigger Procrastinator
    22 Mar 2004
    The following should get some of the specs:
    Code:
    $ cat /proc/cpuinfo
    $ cat /proc/meminfo
    $ lspci
    There are various others depending on what you are specifically looking for, but that should get you most of it.
  3. Slim Slotloader
    19 Feb 2007
    Thanks.
    Looking for CPU, mobo, vidcard, memory, hdd.
    Where do you input these codes exactly?
  4. trigger
    22 Mar 2004
    You can just input them at any terminal (e.g. Konsole in KDE, aterm, xterm, whatever). You may need to be root though (just type 'sudo' before the commands if he's on Ubuntu, otherwise use 'su'). For the hdd you will want:
    Code:
    $ df -h
    Not sure about the mobo though - you might need to get that from thew BIOS.
  5. Slim Slotloader
    19 Feb 2007
    OK, thanks a lot....really got to look into linux someday=)
  6. simon w
    simon w What's a Dremel?
    3 Nov 2003
    lshw will tell you all that :)
