News Firefox 2.0 Final out a day early
Discussion in 'Article Discussion' started by Da Dego, 23 Oct 2006.
  1. DougEdey
    5 Jul 2005
    Mine is still build 2006101023 and hasn't prompted me to upgrade
  2. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    its looking good though, "seems" to run smoother than 1.5 did on this machine, good work mozilla!
    c.u.later
  3. speedfreek
    speedfreek What's a Dremel?
    9 Nov 2005
    Im debating installing it on the school computer im on right now.
  4. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    well, half an hour in, it has crashed. Maybe it was just trying to show me the "restore session" feature. That crashed it again though.
    And then, just as I was about to write that, it froze again!
    It's odd. Both crashes happened when I navigated to a page on the bit forums. Maybe it doesn't like something in Vbulletin....
    Apart from that, I really like the idea of the inline spell checking, but the dictionary is woefully bad. Keep having to pop up to the google bar to get the correct spelling. I think it is learning without me telling it to though. Thumbs up on that one.
    Think I will try IE7 in a bit.
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
  6. dom_
    dom_ --->
    4 Jan 2004
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    :thumb: (though I set mine to "2")
    Sadly that's the Achilles heal of FF. I lost 4/8 (AspellFox, Fasterfox, Tab Mix Plus, & Tabbrowser Preferences) but some of those functions are now integrated. I also lost the theme I was using. Spell check works nice though :thumb:
  8. quack
    quack Minimodder
    6 Mar 2002
    RC3.
    You can force extension compatibility with Nightly Tester Tools in most cases (until the extension is properly updated).
    Fasterfox works great after forcing, and there's an updated TabMix Plus on the official site.
  9. Ben
    Ben What's a Dremel?
    11 Aug 2003
    Install the "nightly tester tools" extension, it can disable the extension version check and dose some other things. A lot of extentions still work fine.
    edit: bah quack.
  10. Lazarus Dark
    Lazarus Dark Minimodder
    14 Apr 2006
    ahh!!! it killed my blackjapan theme! too much gray! hopefully it'll get updated soon its a popular theme. killed a couple extensions, but they're integrated now like tab-x. speelcheckar is sweet!
    should this really be 2.0? the changes seem minor to me. seems like it should be 1.6 or something. but then again how much more can browsers be improved? maybe a 3d browser! I call patent!
    to the above crapintosh fans ^^^ I got opera a month ago and meh. its okay i guess. its nothing special. Firefox larger user base means more people to work on improving it and adding themes, extensions, so unless opera surpasses ff in popularity I'll stick with ff. I will Never trust ms with my internet again, they have run out of chances with me so not interested in ie7 or even ie10
  11. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    The bookmarks synching extension that I previously used doesn't work with V2 - anyone found one that does work in V2?
  12. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Everything seems fine with it, however has anyone noticed a slightly longer load time?
  13. allforcarrie
    allforcarrie Banned
    22 Jul 2005
    :rock: :rock: :rock: :rock: :rock: :rock:
    Now all i need is a theme to look like 1.5.
    FOUND IT!!
  14. Spaced_invader
    Spaced_invader What's a Dremel?
    25 Sep 2002
    found a bug in it already lol after using it for all of 30 seconds.. if you close the last tab with the close tab cross the program doesn't exit, it just leaves you a blank tab... doesn't really seam like a feature to me lol...
  15. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Agreed, however as long as people use anything except IE, I'm happy :thumb:
  16. Emon
    Emon What's a Dremel?
    14 Jun 2004
    I like Opera a lot, it's a fantastic piece of software. But Firefox offers so much more customizability it's not even funny. Most people would be content with what you can do with Opera, but people like me use specialized extensions that aren't really available elsewhere.
    I encourage people to at least upgrade to IE7. I like IE7, it's pretty good. What I dislike most is the horrible UI responsiveness when working with tabs. Sometimes it's snappy, and other times it gets stuck on a tooltip or something, which half shows up, then chugs for a few seconds before a tab opens or closes.
    As for the "memory leak" in Firefox, yes, it is a page caching feature. I think it would be very wise to make it more blatantly optional, however. Even a simple "speed vs memory" question during install would be fine. Additionally, while I like things like built in spell checking and anti-phising, a better design approach would be to make them extensions which come with the installer. They would install by default, but still give users the option of removing or disabling them. This way you can easily cater to people who love such features and others who would curse it as bloat.
  17. Drexial
    Drexial Minimodder
    28 Jul 2005
    well IE7 has left me no choice to go with FF (not that i wasnt going with firefox anyway) bit i figured i would give IE7 a try.... the adress bar doesnt work with any adress i have typed in it. if i type a phrase it sends me to google and the google search bar works.... but no adress does anything. i can still click on links on teh default MSN page and search.
  18. gideon
    gideon What's a Dremel?
    27 Feb 2006
    It was leaked out a few days ago, but i like the new skin and haven't had any problems the last day :thumb:
  19. Firehed
    15 Feb 2004
    It should be a release candidate that gets released, believe it or not ;)
  20. hughwi
    hughwi Minimodder
    23 Dec 2003
    you need to install the English dictionary as an add-on apparently ive just tried it and it work perfectly :D its got Microsoft word-like red underscores :D
Tags: Add Tags
