Networks firefox,outlook and links
Discussion in 'Hardware' started by Piratetaco, 2 Aug 2004.
  1. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    when every i click on a link in outlook it ether lauches a new FireFox window or opens 2 new tabs in firefox.anyone know how i can stop this from happening(and no use IE muppetry)
    thanks
  2. Abadon
    Abadon What's a Dremel?
    17 Jul 2004
    this might help fix it
    go to tools> options> advanced> browsing> select new tabs from opened links
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    sorry this won't help, but...
    wierd thing happens for my dad - he clicks on a link in Outlook (or even Eudora) and get both an IE and a FF window!
    Also, msnger always opens weblinks in IE, no matter what settings are used - damn MS!
  4. quack
    quack Minimodder
    6 Mar 2002
    To fix the IE/FF problem, you gotta fix the HTTP reference in the registry. The installation program doesn't seem to bother changing the DDE setting.
    1. Open My Computer.
    2. Click Tools, Folder Options.
    3. Click on File Types.
    4. Scroll down to (NONE) URL:HyperText Transfer Protocol.
    5. Click on Advanced.
    6. Select Open.
    7. Click Edit.
    8. Make sure the settings are the same as in the image below.
    And to stop FF opening new windows, try downloading Tabbrowser Extensions, and set it to "Use only one browser window always"
  5. Piratetaco
    15 Apr 2004
    Quack thanks a lot thats just fixed it
    :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
  6. quack
    quack Minimodder
    6 Mar 2002
    You're welcome. :)
  7. jezmck
    jezmck Minimodder
    25 Sep 2003
    cheers quack, will show that to my dad.
    :thumb:
  8. cjmUK
    cjmUK Old git.
    9 Feb 2004
    I've been meaning to ask this on here for ages, but never got off my lardy arse to do it.
    Cheers Quack...
  9. quack
    quack Minimodder
    6 Mar 2002
    Glad to be of service :D
    If only PCs came installed with Firefox instead of IE, would make my life happier. I hate using IE for anything but Windows Update and Office Update.
  10. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Just purchased & configured a new pc for my mum... I set FF as the default browser, so I'm doing my bit to convert the masses.
    However, we are all suffering from websites that are designed poorly or for IE specifically. So IE still comes in useful...
    Hopefully, improvements in FF and others will mean that they become preferred to IE - given that IE isnt going to change until Longhorn, and only Early-adopters will get it before the end of 2006.
    Cheers
  11. quack
    quack Minimodder
    6 Mar 2002
    And this is where the extension IEView comes in handy :)
    Sometimes I have to flick into IE because 1) AdBlock has blocked half the images on a website because of one of the regex rules 2) the page is designed so badly it only works in IE.
    The sooner people embrace CSS and XHTML the better.
  12. Hippo
    Hippo Pre-dates 5.25" Floppies
    7 Mar 2003
    IEView is the add-on that removes the last annoying thing from Firefox.
    Firefox Rules O.K.
  13. jezmck
    jezmck Minimodder
    25 Sep 2003
    well mine has stopped updating itself, it appears they think my key is invalid.
    didn't think that'd happen until SP2, which is why I wasn't going to get it.
  14. cjmUK
    cjmUK Old git.
    9 Feb 2004
    Would they be wrong about that?
  15. Piratetaco
    15 Apr 2004
