Modding first mods?
Discussion in 'Modding' started by Ab$olut, 23 Dec 2004.
  1. Ab$olut
    Ab$olut What's a Dremel?
    22 Dec 2004
    Ok now ive seen all these cool cases and so forth now I want to do my own modding what would you suggest as first mods? or what mods did you do first i'd like something cheap and easy to do at first so it won't be much of a loss if a F**K up I already have a led fan on the back of my case but that was way to easy.
    Cheers uldis :thumb:
  2. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    There are a ****load of these threads lately...Lots of new members, lots of new modders. Not saying it's a bad thing, but eventually people will stop replying... :search:!. Simple first mods are to put a window in your case, maybe wire up some LED's and put them somewhere, or create a simple chaser circut to control them. CCFL's are easy, and pretty common. Stealth your drives, that's an easy mod. :thumb:
    Welcome to Bit, btw!
  3. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
  4. Ab$olut
    22 Dec 2004
    I think i'll go for a window first but I aint got a dremel :dremel: :duh: will have to get me one of those and a neon I think will be simple enough :hip:
  5. Freaky_Tweak
    Freaky_Tweak What's a Dremel?
    11 Oct 2003
    my verry first mod was radom xbox controller light.. but that is long ogne.. sorry to say.. maybe sometime ill do V. 2. my first computer mod was a window, but not the average:
    i used a jisaw to do that, and it was simple and straightforward: drill pilort hole, cut the stuf out.. repeat endlessly. its all what you are willing to try and what you are good at. anyway, good luc and post the results.
  6. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    O.T. but Freaky, how the heck do you have an avatar?
    uldis, i'd suggest some simple sleeving and wire management followed up by a simple window.....that is if you like windows.
