floppy drive through PCI or something
Discussion in 'Hardware' started by Urza9814, 12 Jan 2005.
  1. Urza9814
    Urza9814 What's a Dremel?
    12 Jan 2005
    Ey, I recently fried my motherboard's floppy drive controller...is there any way to use a floppy drive other than sending in my mobo for the warranty? I don't wanna go the week or two it'd take to do that with my old comp, and I don't wanna have to rebuild my entire comp...so...any kinda PCI card or something I can use? only thing I can find is ISA cards...
  2. BaDDaSS
    BaDDaSS What's a Dremel?
    30 Oct 2002
  3. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    how much do you really use your flopply drive why don't u just get an external usb drive
  4. BaDDaSS
    30 Oct 2002
    Im partially reluctant to by a floppy drive for my new rig.
    I have cdr/dvdr and zip - who uses floppies these days?
    *cough* my mum :(
  5. Urza9814
    12 Jan 2005
    I have a good reason to use floppies.
    1) CD-RWs are not, in fact, rewritable (except Radioshack's, but I can't find those anymore)
    2) my school uses win98, so I think USB pen drives are out (plus they're expensive as hell)
    3) no one has Zip drives!
  6. TMM
    TMM Modder
    12 Jan 2004
    care to elaborate? i'f you mean you can't really "delete" things, just wipe the whole disc then, yeah, your right... but whats with the ratshack ones?
  7. BaDDaSS
    30 Oct 2002
    They are re writable :)
    USB pen drives can work with Windows 98
    and where im from, most people do have ZIP drives.
    Floppies arn't 100% redundant yet, that wasn't my point.
  8. Xoddoza
    Xoddoza What's a Dremel?
    13 Jun 2004
    Correct me if' i'm wrong, but you need Floppy drives for SATA/Raid drivers and Bios flashes.
  9. Urza9814
    12 Jan 2005
    yea, I believe you are right...lol...will a USB floppy drive work for boot disks though?
    And by CD-RWs...I meant usually they can only be rewritten about 3 times before the comp says they're corrupt...except Radioshack's...I had a pack of those that lasted about a year and a half...
    and yes, you can delete things from RWs...depending on how they're formatted though...
    USB pen drives work with 98 out of the box? Like, no drivers? Still though...they're expensive as hell...
  10. Xoddoza
    13 Jun 2004
    I don't think USB Floppys work with boot disks but i'm not 100% sure.
    -Xoddoza
  11. Sea Shadow
    Sea Shadow aka "Panda"
    15 Jan 2004
    :confused: I have used the same set (i got a pack of 5) of CD-RW for years, and they still work fine. I can't count the number of times I have Re-Written them but best guess is well over a hundred. They still sell the same exact discs at my local office max. (They are TDK)
    And pen drives are very inexpensive these days, heck sometimes you can get them for free after rebates :clap:
  12. Sea Shadow
    15 Jan 2004
    Oh yeah, I have had one CD-RW die on me. But that was after it was scratched so bad that I could see light through the disc when held up to a light.
  13. Firehed
    15 Feb 2004
    Depends on the mobo I think.
    Floppies are the most outdated tech still in existance. They serve no day-to-day purpose, in fact the sole purpose of F6 drivers if you're installing windows to RAIDed drives (and BIOS flases if your mobo doesn't support a windows-based flash which many do). Data is easily corrupted, they cost ~$500/GB if you buy in small packs (CDs costing ~9c/GB and DVDs even less). In fact you can get a cheap CDRW or USB pen drive for the same cost as a floppy drive and a couple disks.
    True not that many have zip drives, they're only marginally better than floppies (at $100/gig it's rediculous)
    USB drives work in Win98, they just need a driver. Why you can't just email the files you're working on to yourself perplexes me, it can't be that much of a problem if they'd fit on a floppy.
  14. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Dont you also need to have a floppy to install drivers for windows XP to read SATA drives in general for installation?
  15. Xoddoza
    13 Jun 2004
    I belive so. I just plug it in, install the drivers then unplug the floppy.
  16. TMM
    TMM Modder
    12 Jan 2004
    i slipstreamed sata drivers onto a windows xp cd so i don't need a floppy anymore when formatting my comp ;). Thats the only reason i ever used a floppy drive and now i don't need to do that anymore :clap:
  17. Arkuden
    Arkuden mow?
    9 Jul 2004
    TMM care to share any info on how you accomplished this. Ive seen a few sites but they didnt quite cover what you just said.
  18. moddenmania
    18 Sep 2004
    usb flash drives aren't too expensive
  19. TMM
    TMM Modder
    12 Jan 2004
    http://unattended.msfn.org/ ;) half the time i didn't really know what i was doing :hehe: , but i just followed on very carefully and it works great :)
  20. Urza9814
    12 Jan 2005
    see, the biggest reason I need one is for school. I can't install drivers, I can't access my email, can't access my FTP server, and they don't have zip drives...just floppy and CD...
